Astro Saber 3 Secure ?
Armadillo5
North Texas
Under the "Secure Configuration" section of the CPS there is a box to check that is called "Secure Hardware Equipped".
Do I need to select this option to turn the Secure Module on?
Also, once that box is checked the OTAR box light's up for me to check and when I check that one the next box over light's up for "Generate Key-Loss-Key". What does this mean? I know what OTAR is unclear on the meaning behind these boxes and or options.
Thank You for the help and sorry if someone has already answered this.
mm
oregon
Yes you need to check the enable secure box to enable the secure module.
Generate key loss key is used with OTAR to automatically send a request informing the KMF that you have lost your radios shadow key which is used to OTAR.
Since you lost your Shadow key your radio will automatically request that the KMF reload the shadow key only so that you can then OTAR.
Mike
