Astro Spectra CPS on Win 7??
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Buy the software, install it and install the CPS into it.
Mars_P25
Paid RR Supporter
Banned
Guys, to run old CPS (XP era) on Windows 7 -- especially 64-bit, you need to download and install Windows Virtual PC, and Windows XP Mode. These downloads are free from Microsoft, provided you have a genuine copy of Windows 7 installed.
Install and use Windows XP Mode in Windows 7
I'm using this setup in a Windows 7 64-bit native environment, with a ioGear USB-Serial adapter, to program MTS2000s, MCS2000s, ASTRO Saber/XTS3000 and ASTRO Spectras -- with the SRIB. No problems/bricks ever encountered.
BigEd1314
London, KY
I have a windows 8 laptop, got xp virtual machine running. I try to read my astro saber and the radio starts to read, radio beeps, and "1 CSQ" displays on the screen, then the CPS displays that communication has failed. Any ideas what might be the problem? Cables and rib work fine when I last used them on a xp laptop, I just no longer have access to that computer. Thanks in advance.
Ed
brndnstffrd
CT
Is it a fresh install of Windows 7 or is it a copy that has been upgraded from a previous version. Sometimes programs will not be able to run on a copy of Windows that has been upgraded.
I forget which, but one version of CPS even says that it will not run on a copy of Windows that has been upgraded from a previous generation, only a fresh full install.
EDIT: This is what i was thinking of, I found this in the MTS/MCS CPS Readme, the same is also in the Astro Saber,Spectra, and XTS3000 CPS:
System Requirements:
Operating Systems: Windows NT 4.0 (SP 6a or higher),
Windows 2000
Windows XP Home Edition (See Note)
Windows XP Professional (See Note)
Vista (32-bit) Home Premium (SP 1 or higher)
Vista (32-bit) Business (SP 1 or higher)
Note: XP upgrade or Vista upgrade from other operating
systems is not supported if the CPS was previously
installed on the old operating system.
Windows ME and Windows 98 are no longer supported.
You may choose to proceed with the installation, but
some features might not be functioning properly.
Upgrading the operating system is highly recommended.
I didnt see it mentioned in the Waris CPS.
Also what Mars said is good advice too
