Astro Spectra Install
Project25_MASTR
TX-COMU
Texas
i had problems when i used 2 Motorola Maratrac's in my car then i came up with the 75AMP relay it fixed my problem never a dead battery.
Sounds like the iginition sense wasn't on a switched source…if the ignition sense is true, the radio will draw current even when off. If false, the radio will only draw a handful of milliamperes.
cmdrwill
So Cali
I have an Astro hi power on the bench now, I will measure the keep alive current. I remember just about 5 mA or so.
Close, the VHF on the bench draws 1.75mA on the main power cable with the radio off. < 5mA.
The Green and Orange leads draw .2 A max with the radio On and control head display at max brightness.
The IGN sense, Orange draws .2mA with the radio off, Green lead has no current draw with the radio Off.
toolman60
Will,
Thanks for the bench test remarks. So with only less than 2ma draw that truck should sit for a few months without pulling the battery down. If weather and everything goes according to plan should be doing the radio install this weekend or next weekend.
cmdrwill
So Cali
Will,
You are very welcome, glad to help.
