Astro to XTL upgrade
Echo4Thirty
Not without the correct model number change between the two series.
All thats required is to change the TIB and control head, then in CPS go to tools then Change Control Head. It will update the codeplug to the desired head. Write to radio. I have found it might be eaiser to do this with the OLD control head attached, then change the hardware.
mpcpsrego1
Nebraska
Ok so a little update I placed a new TIB MHLN6883E but to my surprise the TIB on the brick was also a MHLN6883E so either way when I pull the CPS and go to change the head its shown as a W3 and when I select W9 its prompting me that the hardware doesn't support a W9. So do I just push it through and program it or do I need to hook up a W3 head? I am not understanding why the radio thinks a W3 was connected when the TIB was not even W3 capable? Sorry if this is a laborious conversation but to me this is how we learn so I am gonna keep at it until I make it work
So I unhooked from the brick and still have the CP pulled up and advanced it by saying YES to change it from W3 to W9 and a window that says: Warning! changing the CH type might reset certain button values and truncate fields that do not fit the new display size. It is recommended that you save the CP(already did when I first received the brick) before proceeding.
I am gonna assume my vendor accidently set it to a W3 head and wrote the radio? It was originally set for a W4 head which explains why it has a existing MHLN6883E TIB because its all original equipment
