BCT15X: ATC
colerey
louisiana
I am a very new user here, I have successfully programed in my local tower, ground, and ATIS channels into my BCT15X, however, I do not know what the appropriate modulation is for these frequencies (AM, NFM, FM, WFM, FMB), does anyone know what modulation I should choose (will auto do the trick)? Thank you
Saint
Fort Erie Ontario Canada
Aircraft are all AM
aprswatcher
Lewistown, Montana
The BCT15X is one of the Best airband scanners! It handles VHF and UHF communications well.
Use “Airnav.com” to look up new frequencies for surrounding airports and military bases.
Select the “airports” tab, enter airport/base name, then scroll down to the “communications “ section for frequencies.
Welcome to Radio Reference and enjoy your new scanner!
73, Rex
n1chu
Farmington, Connecticut
“Auto” will work for those frequencies you don’t know what mode they use (the scanner will choose for you) but commercial aviation uses AM. Military may use both AM and FM. When in doubt use “Auto”.
You can (and should) experiment with your new scanner. In this case, simply entering the frequency in question twice, using AM on one and FM on the other, should give you a good idea of how the signal sounds using the different modes of modulation. Once you hear the difference you will know which mode you should use.
The tower and the commercial airliners both use AM. Because AM behaves differently than FM. On AM if two airplanes are transmitting at the same time on the same frequency the two signals “mix” and produce a squealing, called “heterodyne”… it’s the same squealing noise prevalent on AM CB. If FM were used the stronger signal may win out and completely cover the weaker signal. Control towers can discern when two aircraft are transmitting at the same time when AM is being used. AM heterodyning alerts the tower that two seperate airplanes are responding to the tower’s instructions. It comes in handy when two aircraft are thinking the tower is instructing them to land for example. The tower hears heyrodyning, realizes there are two aircraft thinking the tower is talking to them and corrects the mistake, avoiding the chance two planes may collide while landing.
Smaller airports that do not have Air Traffic Controllers on duty use a common frequency assigned to that airport. Each airplane transmits their intentions to land or take off on that one common frequency and all other planes that are in the vicinity of the airport listen intently when they want to enter the landing pattern for the airport. (They fly parallel to the runway, making their final turns to line up with the runway, transmitting each time they make a turn with their intentions. These smaller airports without ATC (air traffic control) all use AM.
nd5y
Wichita Falls, TX
That's not how it works. Auto sets the mode according to a built in band plan, it doesn't change based on the actual received signal.
  • Like
Reactions: wtp
n1chu
Agreed. But my “Scanner 101” explanation was not implying otherwise. As far as the aviation bands go, my explanation stands. Band plans is included in the advanced “Scanners 102” course.
Besides, if the menu includes the option of “Auto”, when manually programming within any particular band, it’s assumed it’s available on that band. How many bands do you know of that don’t include the “Auto” choice?
wtp
Port Charlotte FL
auto just means a preset band plan.
it can be edited.
BCT15-X Auto Step Sizes/Auto Modulation
Band Defaults
Frequency Range
Step (kHz)
Mode
BandFrequency Range
Step (kHz)
Mode
Band
25-27.405
5​
AM​
CB/Business174-215.95
50​
WFM​
VHF TV
27.41-27.995
5​
AM​
Business/Forest216-224.98
20​
NFM​
1.25 Meter Ham
28-29.68
20​
NFM​
10 Meter Ham225-379.975
25​
AM​
UHF Air
29.7-49.99
10​
NFM​
VHF Low380-399.9875
12.5​
NFM​
Military Trunked
50-53.98
20​
NFM​
6 Meter Ham400-405.9875
12.5​
NFM​
Miscellaneous
54-71.95
50​
WFM​
VHF TV406-419.9875
12.5​
NFM​
Federal Trunked
72-75.995
5​
FM​
Astronomy420-449.9875
12.5​
NFM​
70 cm Ham
76-87.95
50​
WFM​
VHF TV450-469.9875
12.5​
NFM​
UHF Standard
88-107.9
100​
FMB​
FM Broadcast470-512
12.5​
NFM​
UHF TV
108-136.9916
8.33​
AM​
Commercial Air758-787.99375
6.25​
NFM​
Public Service
137-143.9875
12.5​
NFM​
Military Land Mobile788-805.99375
6.25​
NFM​
Public Service
144-147.995
5​
NFM​
2 Meter Ham806-823.9875
12.5​
NFM​
Public Service
148-150.7875
12.5​
NFM​
Military Land Mobile849.0125-868.9875
12.5​
NFM​
PS Trunked
150.8-161.995
5​
NFM​
VHF High894.0125-960
12.5​
NFM​
Public Service, 33 cm Ham
162-173.9875
12.5​
NFM​
Federal1240-1300
25​
NFM​
25 cm Ham
When you select 'AUTO' for a channel or mode’s modulation or step, the above values are used unless you’ve edited the Band Defaults. Although TV bands are listed, the scanner cannot decode digital TV audio.
n1chu
So, you’ve just answered my question with “Pretty much all”… not that it’s going to mean much to the “newbie” OP who probably hasn’t a clue as to what you are describing.
Your input, while correct, is “too much information” if it’s an attempt to answer the OP’s question. He’s a newbie.
If it’s an attempt to respond to my post, then not only are you hyjacking the original post, you are attempting to admonish me with your initial reply “That's not how it works”, meaning what I wrote is incorrect, when in fact it is not. Now that you have showed everyone how much you know, you can relish in the thought “Boy, I guess I showed him!” and be on your way.
colerey
louisiana
Thank you all for the help, I am now finding some success in listening to ATC. One final question I have is if I am about 15 miles from kbtr, is there any antenna or antenna placement that could pick up those channels or should I call it a day? The only frequencies I can pick up currently are some hazy Houston Center frequencies.
aprswatcher
Lewistown, Montana
Program in the frequencies for Ryan Field, you never know what you will hear. The back of the set telescoping antenna is ok, but not great. If you’re real serious about hearing more communications, I would suggest an external antenna. A discone antenna covers numerous frequencies or get an air band specific antenna. Check out DPD production for some excellent antennas.
73, Rex
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Air Traffic Communications will ALWAYS be AM. Even for military ATC.
tvengr
Well Known Member
Baltimore County, MD
Here is a list of ATC frequencies for Ryan Field. There is one UHF frequency for the tower and another for approach/departure. You will need to lockout the ATIS frequency. It is a continuous transmission with airport info.
BatonRouge Metro
118.450KBTR Tower VHF
257.800KBTR Tower UHF
121.900KBTR Ground
119.400KBTR Clear Deliv
122.950KBTR Unicom
125.200KBTR ATIS
120.300KBTR App/Dep W
133.225KBTR App/Dep E
278.300KBTR App/Dep UHF
121.500Aero Emerg VHF
243.000Aero Emerg UHF
