Athens County Engineer / Jackson County Engineer
phase_lock
I didn’t hear anything from the Athens County Engineer / Highway Department during the snow events earlier this month. Does anyone know if they are still using 151.2575 MHz?
I’ve also not heard the Jackson County Engineer / Highway Department on 453.375 MHz in quite some time. I periodically hear a strong digital signal on this frequency (not sure what it is as I have no DMR/NXDN-capable scanner at present), but the database still shows them on FM. Can anyone shed light on this one?
Neither entity has a MARCS talkgroup listed in the database as far as I can tell.
Thanks in advance for any insight.
W8UU
Pilot of the Airwaves
Wellston OH
Jackson County did a huge push to MotoTrbo a few years ago dumping almost all their analog equipment. They reused 453.375 MHz for the County Engineer main frequency using MotoTrbo and also licensed 453.775 MHz for a low power "shop frequency" at their Clary Road office and road maintenance depot.
I'll check on Athens County and let you know.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
If you have color code and talk group information for any of that DMR stuff, could you submit it please?
Mike
W8UU
Wellston OH
Mike
I'll try to get that. I don't have the ability to monitor MotoTrbo but I know the guy who decommissioned all the analog stuff.
W8UU
Wellston OH
Looks like the Athens County Engineer is on MARCS, check page 2 on their 2022 annual report
Yes, they are. Got that confirmed this morning.
I'm guessing their VHF system (and a nice one, at that) was abandoned in place.
On Jackson County, it looks like most or all of the MotoTrbo system that was shared by EMS and Fire was given to the County Engineer.
EMS and Fire is on MARCS except for analog alerting on 453.3125 MHz (EMS) and 453.625 MHz (Fire).
The 453.375 MHz County Engineer repeater is now part of the MotoTrbo system.
Still waiting on color codes and other technical data.
NikonFE2
Ohio
Athens moved to MARCS. I listened to them all during the snow event. TGID 7042
W8UU
Wellston OH
The Jackson County Engineer is using the county's MOTOTRBO UHF system. The old county engineer analog repeater frequency pair (453/458.375 MHz) is now part of the county's digital system. It's shared with the fire departments, Wellston Police, and eventually Wellston City Services. You'll need a scanner capable of decoding MOTOTRBO transmissions to receive it.
The county engineer's 453.375 MHz and Wellston Police's 453.675 MHz frequencies aren't listed in the RR database as being part of the county DMR system -- but they are.
I'll check with my contact at Jackson County about any other changes and send something in for an RR Database update.
Hope this helps.
phase_lock
Rick and Nikon, thanks very much for the updates.
I listened to 453.375 during the big storm in early January and heard quite a bit of traffic. The last several weeks, nothing at all. I double-checked my programming today and all looks good: channel not locked out, audio type set to digital only, tone/code set to search. Any ideas?
wa8pyr
Lead Database Admin
Ohio
County engineers aren't typically too chatty unless there's bad weather or something else to really talk about. You may have to wait until the next big snowstorm.
And if that frequency is part of the county DMR trunked system as W8UU says (and I believe him), then you might try programming the entire system.
