I sent the note below as a PM to the two database admins for Santa Clara County. I would like to expand the audience and ask some more questions.
The executive summary is that the way many California counties have their database setup does not create an intuitive hierarchy in the Uniden Homepatrol software. The issue is that many subcategories are setup per-function and not per jurisdiction. There is a 'subsection' per city that isn't recognized by HP-1 software. And then the subcategory is simply 'Fire', "Police, etc. The result is that the subcategory is not useful, since it is listed as "Police" and you have no idea what police is being referenced.
I have seen other counties, and their subcategories are jurisdictional. So you have "Los Altos, City of" and then under this, you have Police, Fire, etc. The subcategory now shows the proper jurisdiction.
I'll upload a screenshot of Santa Clara County so you can see the issue. And then you can poke around to the other database pages to see how it is done 'correctly'.
Thanks for your time!
1. As I poke around other counties, I see similar issues. Just a few to point out, and these are just counties I visit, not to pick on folks:
Kern:
Kern County, California (CA) Scanner Frequencies and Radio Frequency Reference
Ventura:
Ventura County, California (CA) Scanner Frequencies and Radio Frequency Reference
Santa Barbera:
Santa Barbara County, California (CA) Scanner Frequencies and Radio Frequency Reference
2. The other question, is what is the most productive way to advise folks to update their sections? Is this message good enough? Should I submit information like other information? It seemed a bit out of place for a basic/wide sweeping change.
Anyway, not trying to cause trouble, just trying to help make the HP-1 the best it can be!
I apologize for the vague title, but I've never been as interested in the rr.com database until now. I'm sort of working 'backwards' so please bear with me. I fired up the HP-1 Sentinel software to see how Santa Clara county was represented, and it shows:
California \ Santa Clara \ County Systems \
...and then
... \ City Services (*13)
... \ Police (*~10)
I think the problem is the way subcategories have been used. All of the subcategories are 'City Services', 'Police', etc.
Here is the link to Santa Clara County:
Santa Clara County, California (CA) Scanner Frequencies and Radio Frequency Reference
If you take a look at Riverside county:
Riverside County, California (CA) Scanner Frequencies and Radio Frequency Reference
...you'll see that the subcategories are more descriptive "Banning, City of". It really helps in the hierarchy display of information.
So let's take Campbell as an example.In the blue subheading line, it shows Campbell, City of. This information isn't used by HP-1. And then the clickable link just below says "Police". I think it should be "Campbell, City of". Then under this subcategory, we need to put all of the Campbell frequencies for PD and PW.
Like I said, if it isn't clear, check out:
Look at the City of Hemet as an example.
Kern:
Ventura:
Santa Barbera:
...and then
... \ Police (*~10)
