Attn: All scanner buffs check this link out!!
N4DXX
In the pines where the sun never shines
http://xoomer.alice.it/aporcino/VoiceDescrambler/index.htm works great when running a scanner thru your soundcard!!I assume no responsibility for the content of this link as i know we are all law of the land lovers and would never use this to descramble anything..I am in no way liable for it's use or abuse i just found it while surfing..What you do with it is up to you i am just leading a few horses to the water it's now up to you to drink it..73's
car2back
Tulsa, OK
voice inversion huh? don't see much of that around my way :(
Now if you can just 'stumble' across software that will do Provoice ;)
N4DXX
A few local sheriff depts use it here kinda cheap high tech..i think ...if you use speech inversion you might be a redneck...or something khz to answer the ? i think...may be hz more likely than not..
N4DXX
Beam me up scotty...I am on it will let you know on the provoice thing...as with google i will find it..
gcgrotz
Savannah, GA
Thanks! Now I can find out where yellow cab is sending all of their cars (he said sarcasticly).
I might try it just to see if it works, I have no reason to listen to cab dispatches otherwise.
