For those of you helping with WireShark traces:
First of all, thank you very much for investing the time and effort in helping find this problem. I appreciate it, and a lot of people in the community also appreciate it (er, or, ah, they will when the problem is ultimately fixed).
Second, what I need you to do are the following:
1. Download and install WireShark on the system from which you're running ScannerCast -- take all the default settings. Just keep hitting "OK" and "Next>"
2. Reboot.
3. While ScannerCast is running correctly, try a couple of test captures. Just start WireShark and click on the same interface that you're using for ScannerCast in the "Start capture on interface" section (on the left side of WireShark's initial screen. You should see a bunch of packets captured.
4. If the test capture fails to start, or no packets are shown (Click "Capture" Stop)... Click on Capture Options (shown just under the list of adapters) and clear the "Capture packets in promiscuous mode" check box (left side of the dialog) and THEN click start.
5. If the capture fails to start or no packets are shown, I'm out of ideas. Thanks, but WireShark isn't working for you. This is very unlikely.
6. If the capture works, let it run for a minute or so... then stop the capture and save it to disk. Name it "Working capture" or something.
7. THEN, when you experience the problem -- ScannerCast says it's still running, but RR reports that your feed is down -- start a new capture... let it run for a minute or so... and then stop the capture and save it to disk. Name it "Problem capture" or something.
8. Email me both captures (your test and the problem capture -- I really do need both), or put them someplace that I can download them.
9. I'll analyze the captures and let you know the outcome.
I really, really, appreciate everyone who's willing to help. This is a historically difficult problem, Lindsay's gone above and beyond the call of duty in trying to help rectify it, I've spent too many hours to count trying to rectify it, and the only thing that'll help us at this point is the WireShark trace.
When we have the results of the trace, either Lindsay will make some change at RR or I'll issue an update to ScannerCast that fixes the problem.
Thanks, thanks, thanks,
Peter
K1PGV
