PSR-800: Audio files
White Bear, Mn.
Hello, what do you guys use to merge your .au audio files into a .wav or .mp3?
I have been using Audicity and thinking there has to be a easier way.. Thanks......Jim
I use Audacity .. it actually works very well once you get the process down.
I use .. File -> Import -> Audio, Edit-> Select-> All, Tracks -> Align Tracks ->Align End to End, then File -> Export Audio.
I use 16 kbps .. that seems to be the smallest size that still gives reasonable audio quality.
