Okay well even though you tightened the SMA connector so that there is no play or less play you may still have a poor connection of the antenna to the radio. The solder may have broken.
I've had my 436 since 2014 and really don't use it anymore so personally I would probably try to tinker with the radio by taking it apart and trying to repair it myself by soldering the connection. Don't know if you're going to want to do that or if you are on warranty but your radio might need repair from Uniden. I assume this is a change in reception to what it used to be and that the choppiness goes hand-in-hand with the loose SMA connection.
Lots of smart people here who are probably more familiar with this problem, let's hope they see our posts and have some suggestions how you might be able to repair it yourself, I can't imagine it would be that hard.
