RFI-EMI-GUY
- Joined
- Dec 22, 2013
- Messages
- 7,631
If you are connecting the speaker output or headphone output of your scanner or any other receiver to a sound card or mixer or any other unbalanced device (with Phono plugs and Stereo jacks), beware that your radio may have a Bridged Tied Load (BTL) amplifier. In fact, unless it is a very old style radio, it probably has such circuitry. You should never connect anything except a speaker, headphone or an audio isolation transformer to the radio. You will likely damage the amplifier because it provides reference directly to A+ and A- rails in the radio. At best you will have noise and distortion on your Broadcastify feed. Many sound pretty awful in my opinion.
This is what a BTL amplifier looks like:
A description of how BTL works:
en.wikipedia.org
Video below of Big Clive dissecting a stereo isolation transformer. Similar ones were sold by Radio Shack and likely still available. One of these can serve two receivers and two sound car inputs. Note the beefy transfromers inside. There are cheap tiny versions on Amazon that are probably junk and may not actually have transformers inside, just capacitors to lift the voltage from the audio. The BTL may not be happy without the DC continuity of the transformer winding, so don't buy unless it actually has transformers. Big Clive is describing its function as normally used, to safely reduce power line hum and noise from a stereo system.
Bridged and paralleled amplifiers - Wikipedia
