Automatic Antenna Switch?
SirSmith
Mount Zion, IL
I recently purchased a 2M antenna with the goal of making an iGate in an area void of one. I was also hoping to use the same antenna to boost the gain of my scanner. Is there a way of connecting both to the same antenna without "blowing up" the scanner when the iGate transmits? Thanks!
W8TDS
W8TDS
LtDoc
Oklahoma
I guess it just depends on how much you are willing to spend. A duplexer is one way, but they are not given away. Sit down before asking price! A second option for that scanner is some other antenna, it doesn't have to be much, almost anything will work to some extent. Not a very 'satisfying' answer, huh?
- 'Doc
SirSmith
Mount Zion, IL
Thanks for the info. I had looked at duplexers but was hoping since the scanner was a receive only application that one wouldn't be needed. Since the iGate operates on one specific frequency would it be possible to split the antenna feed and then use a band-stop filter?
n8zcc
Oakland, Michigan
You will need to notch out the transmit frequency. That is not going to be cheap to do nor it is space saving at 2 meters, you will need a duplexer, like what is used for a repeater.
SirSmith
Mount Zion, IL
A duplexes would allow them to operate simultaneously. I wouldn't mind if the scanner feed got cut out when the iGate transmitted. Is this a possibility?
W8TDS
timkilbride
Linn Co Iowa
For the price it will cost you use the two radio's on one antenna(same band), it would be far cheaper to buy a second antenna and coax.
Tim
