You sure it's not an ELT?
I guess it could well be that, although I would have expected some response from the relevant authorities over that sort of thing being activated.You sure it's not an ELT?
It’s like a warble. I think there are YouTube videos on it.I guess it could well be that, although I would have expected some response from the relevant authorities over that sort of thing being activated.
Edit: What does the signal sound like? Is it a nice, clean and stable carrier or does it wander around?
Heh, I found an RR thread on it too.I guess it could well be that, although I would have expected some response from the relevant authorities over that sort of thing being activated.
Sorry, I was aiming my question at the OP...I know what an ELT sounds like as I have designed them in the past.It’s like a warble. I think there are YouTube videos on it.
Oh gotcha! That makes way more sense.Sorry, I was aiming my question at the OP...I know what an ELT sounds like as I have designed them in the past.
I was wondering what the OP's reported signals on 121.5 and 243 sounded like...
You would be amazed. If they're the old non-406 ones, sometimes it takes days to even locate the location. This is especially true for ELTs that go off in hangars, which happens on a somewhat regular basis. Even after a crash, and the crash site is located, they will often keep going for days until either the NTSB disables it, or the battery runs out.I guess it could well be that, although I would have expected some response from the relevant authorities over that sort of thing being activated.
I experience something similar with my dashcam causing occasional issues with my scanner in my truck....the somewhat noisy carriers I see on these frequencies are due to EMI from aircon units and switched mode regulators.
If you are required to monitor it, get the employer to issue you a REAL radio not a scanner
Thanks for all the replies. I get the dead carrier on pretty much all my radios...Icom R20, R8600, Uniden 436, Whistler TRX2. No matter where I am I get it. Weird stuff.
.You're programing "AM" mode not FM correct?
Yes.You're programing "AM" mode not FM correct?
