Back on the Air..
acyddrop
Delray Beach, FL
Hi all,
I took a break from all things radio related to focus on other projects, but recently decided to get back on the HF bands. I had sold all my old equipment, the last time I was active on the HF bands the FTdx-5000 was relatively kid on the block, and I don't think Icom had released the 7851 yet or if they had it was pretty new. The Kenwood TS-990 had just come out (owned one briefly) when I just lost interest in the hobby. But I decided to get back on the air recently and things have certainly changed a bit even in the short time I've been away. Now everyone is SDR (it used to be just Flex and MAYBE Apache Labs). That suits me just fine, things march on and that's important for amateur radio to carry on. People are still mad that eSSB is a thing so, some things don't change.
I'd be very interested in knowing what some of you out here on the forums are running in your shack, tent, car, etc. Below is what I put together for my new shack and because of the world wide delays in manufacturing due to the human malware some won't be here until 2022. That's ok, I'm not in a rush. 73's to all of you, and thanks for reading!
My shack kit:
  • Yaesu FTdx-101MP
  • Icom IC-9700 (with Leo Bodnar board to fix frequency stability)
  • MFJ 998 Legal Limit Tuner (Maybe not needed, will sell or return if not)
  • KM3KM 160M-6M 1.2KW solid state amp (Not here until 2022)
  • Samlex 30A PSU
  • West Mountain Radio 4005 RIGRunner
  • Vectronic DL-2500 Dummy Load
  • SteppIR BigIR (with 80M coil) 80M-6M vertical antenna with 40 radials 20-32' in length
  • M2 SatPack1 2M/440CM "Eggbeater" Omni-Directional Satellite Antenna setup
  • Comet GP-98 Tri-Band Antenna (2M/70CM/23CM)
  • SSB-Electronics DBA-270 (Dual Band GaAsFET Ultra-Low Noise mast mount preamp)
  • LMR-600 to VHF/UHF Antennas (approximately 40-45 feet)
  • DX Engineering LMR-400MAX to SteppIR BigIR (approximately 75 feet) (I buried this in PVC pipe along with SteppIR control wires)
  • MFJ Window Feed through Panel (Didn't want to drill many holes in house)
I ended up using the DXE radial plate for all my radials and a 1" thick tinned copper braid 18" long from the SteppIR to the radial plate. I will replace this with proper copper strap when I can. My station ground is a pair of 4 foot long copper clad grounding rods lashed together with 1" thick 12" long tinned copper braid and a 1" thick 5 foot long tinned copper braid to the MFJ window feed through. Eventually I will replace these with proper copper strapping for the exterior. Using 1/2" thick 3 foot long tinned copper braid inside and will stick with it.
I'm using an Alpha Delta 2000W surge protector, and put a surge setup on my control cable for the SteppIR along with a 1;1 Choke Balun. My microphones for the two radios are and Electro-Voice RE20 (on the Yaesu) and a Shure SM7B (IC-9700) on Gator Frameworks mic booms. I know this is overkill for both radios, but I own several of these microphones from other work I do and decided to use a couple here. I did have to buy the mic booms and while they're not the cheapest they're the best and aren't all wobbly like the cheaper ones and you can hide the XLR cable inside the boom. I also ended up attaching a 13.3" LCD panel to the Yaesu for a larger display. Since it maxes out at 800x600 it just looked ridiculous on a 24" which is the smallest panel I had, so I ended up with a relatively inexpensive 13.3" monitor that works perfectly for me.
I was originally going to use the Ameritron AL-80B but the delay to get one of those is nearly the same as the delay to get the KM3KM 1.2KW amp and I just decided I liked the KM3KM product better. Also my soldiering skills are good enough to put it together well enough.
acyddrop
Delray Beach, FL
I really like the FT-991A I saw one but didn't get a chance to make any contacts with it unfortunately. I'd considered an FT-991A or FTdx-10 for the base but decided to just go for broke with an end game "premium grade" rig while I had the chance.
How do you find the Xigeu G90? I've heard a lot of good things about it, also that some people find it noisy and hard to work. To be honest I got back into amateur radio following along with the Xigeu G90 story on DXpeditions and such.
FT-991A at home, XIGEU G90 portable.
N4GIX
Hot Springs, AR
I was absolutely gobsmocked when comparing my IC-7300 and Xeigu G90 during a QSO with a gentleman in San Antonio, TX. I used a switch to allow the same G5RV-Jr antenna to be used, and I had the IC-7300 set for 20 watts to make the comparison fairer. The report was that there was no noticeable difference when I transmitted. Both rigs had nearly identical "S" readings 59+.
The received audio was quite noticeably better from the G90. It was richer and exhibited a wider audio response to my ear. It may simply be the difference in speakers between the two rigs.
jwt873
Woodlands, Manitoba
Looks like a great station.. Especially the FTDX-101MP Also I'd like to try out a set of M2 Eggbeaters for satellite work.
I had my own ham hiatus when I wound up in an apartment for a few years. Had to sell most of my gear. But, 18 years ago I moved from the apartment to a house in the country. Since then I've accumulated the following:
Rigs:
Icom IC-7600
Icom IC-9700 (with Leo Bodnar board).
Kenwood TS-2000
Ameritron ALS-600 solid state HF Amp
MFJ 986 1.5KW manual tuner.
Handhelds:
Kenwood TH-D74
Icom ID-51
Motorola XPR6550
Antennas:
HF
Three element SteppIR Yagi (20 through 6 Meters) at 40ft
80 Meter inverted Vee
VHF/UHF
Cushcraft 13B2 - (13 element - 2 meter Yagi)
M2 Antenna Systems 432-6WL - (21 element 70 cm Yagi)
Directive Systems DSE2345LY - (45 element 23 cm Loop Yagi)
Comet GP-95 tri-band vertical (2M+70CM+23CM)
2 meter antenna fed with 1/2 inch Andrew Heliax.
70cm and 23cm antennas fed with 7/8 inch Andrew Heliax
Comet vertical fed with LMR-400
SteppIR HF Yagi & 80 Meter inverted vee fed with RG-213
(Lots of holes in the house :) )
Mobile:
Icom IC-7000 (HF/VHF/UHF)
LDG IT-100 Antenna Tuner
Hustler antenna system with a 54 inch mast and resonators for all HF bands.
Larsen NMO-2/70B for VHF UHF.
And of course it never ends.. I'm looking for amplifiers for my 9700. In the 400-500W range for 2m and 70cm and in the 200 W range for 23cm
N1XDS
ÆS Ø
When I took a break away from ham radio for a period of time I purchased my first Motorola MotoTRBO ION smart radio uhf radio that works really well for Ham-DMR. I also use my Motorola APX 6000XE for VHF and my Harris XG-100p all band portable radio. Welcome back!
- Jamie N1XDS
N1XDS
ÆS Ø
Hi all,
My shack kit:
  • Yaesu FTdx-101MP
  • Samlex 30A PSU
Hi all,
My shack kit:
  • Yaesu FTdx-101MP
  • Samlex 30A PSU
If all possible and if you can would you mind posting pictures of your radio gear and setup? :D
acyddrop
Delray Beach, FL
That's a glowing report right there. How do you find the Xeigu with extracting weak signals out of the noise compared to your 7300? I'd love to get a QRP rig for camping and POTA and I've been waffling on a radio so I'm genuinely curious.
The truly disappointing thing with speakers, at least for example the speakers made by Yaesu (I'm sure this applies to other manufactures too, I can just attest to this with Yaesu). I wanted to get a 2nd speaker to go with the Yaesu FTdx-101MP and picked up one for around $220 from DX Engineering. All it is, is a modestly priced speaker in a box. Not worth the money so I sent it back. I use some inexpensive bookshelf speakers at 8ohms each into the A and B jacks of the Yaesu and they sound better than the included speakers (one in the PSU and one in the radio itself).
I suspect by the time the engineers get around to the audio out they just want to be done with it. That said, the Yaesu sounds amazing but replacing the speakers definitely improved it.
Duckford
Not everyone is going SDR. I went through the pain and bought a 5000 so I can run superhet in the modern age. These damned touchscreens and new fangled crap are for the kids.
jaspence
Michigan
Bought the FT-991A for the coverage as we are trying to downsize. Contacts on HF have been good using an end fed antenna, and having 2 meters and 440 in one small radio saves space and only needs one power supply. Learning curve is high due to touch screen. G90 is very traditional operation and works well at 15 watts on same antenna with 12 volt gel cell.
acyddrop
Delray Beach, FL
I almost got the IC-7610 but in the end I felt the Yaesu FTdx-101D edged it out and I just liked the look of it better. Nothing against Icom, I'm just radio agnostic honestly. That said, I still think the bandscope on the 7610 is a little nicer. I'm not really familiar with the 7600 if I'm being honest. I'm sure it's a fine radio though!
I have to admit I bought the IC-9700 before I knew about it's frequency issues, and as such I generally consider the IC-9700 a "fundamentally broken" or maybe "severely flawed" radio. Having to go aftermarket with the Leo Bodnar board and frequency standard to fix something that shouldn't have been an issue to begin with is kind of unacceptable. That being said, with that in place it's the best base station VHF/UHF rig I've ever used.
My favorite thing about the FTdx-101MP honestly is that it feels like a radio, and not a computer. I spend SO MUCH time in front of computers for work, that I want to sit down in front of a radio with buttons and knobs and engage in the process of using a radio. I know that fundamentally the Yaesu is a computer with a radio, but it feels like a radio. It might be silly, but genuinely I want to think about amateur radio while I'm there and not computers. I also like that you can bring that powerful computer to bear on QRM and pretty much squash it, it's fantastic.
I wish I had the space now for a yagi that SteppIR 3 element is a beautiful piece of kit. Honestly I love the SteppIR BigIR, it was the best choice I could find for what I wanted to do on HF. Continuous coverage with ~1.5 or less SWR from 80m to 6m and it's pretty stealthy and radials once the grass grows over them you forget they're there.
Rigs:
Icom IC-7600
Kenwood TS-2000
Handhelds:
Kenwood TH-D74
Icom ID-51
Motorola XPR6550
Antennas:
HF
VHF/UHF
Mobile:
acyddrop
Delray Beach, FL
I wish Yaesu had never discontinued the FTdx-5000 it's an absolutely amazing rig in every regard. In fact I think it was better than the 101MP (though they are close). Getting through the menus on the FTdx-5000 was easy and infrequent. The pan adapter (SM-5000) was a bit annoying but useful. It's a gorgeous radio in every regard, I'm no expert but I always felt that the 5000 was one of the best radio ever made. But I guess you can't have two flagships, but I don't think the 101MP is a real replacement for the 5000. Yeah the 101MP has some great tech (and is a hybrid superhet and SDR) and VC-Tune is amazing, and so is the DNR. But the 5000 will always be better in my mind.
acyddrop
Delray Beach, FL
Yeah the front panel is pretty compact but that never bothered me honestly. I always considered it a portable QRP rig and while it's bigger than the Yaesu FT-818 for example (it's also more powerful than the 818 to be fair). It's always looked like a solid bit of kit as long as you didn't expect it to be a TS-990 or something in the field. It's been my opinion for a long time that ham radio operators like to complain about everything, haha.
G90 is SDR with very conventional controls. Biggest downside is the size of push buttons. https://www.radioddity.com/products/xiegu-g90-hf-transceiver
jaspence
Michigan
The only reason the G90 small buttons are a problem is I have permanent feeling loss in my fingers that is work related.
jwt873
Woodlands, Manitoba
I'd really like to upgrade my 8 year old IC-7600 to the IC-7610, but no matter how hard I try, I can't practically justify it. The 7600 still servers me well.
The 9700 isn't a bad radio. I'm happy with mine. Unless you're into digital work, you'd never know the rig had an instability problem. It only comes in to play for longer duration digital modes.
I do a lot of Q65 using a 30 second transmit interval. Without the Bodnar board others can see my signal on their waterfall trace 'bending' by up to 20 Hz as my 9700 warms up during TX. (As a side note I managed a 300 mile Q65 contact just last night on 432 MHz).
The Bodnar board fixes it and gets the frequency stability down to 1 Hz. But, the fact that you have to buy third party hardware to get the radio working 'right', is a sore point with most and looks bad for Icom.
AK9R
Staff member
Super Moderator
Central Indiana
I have to admit I bought the IC-9700 before I knew about it's frequency issues...
How are you planning to use the IC-9700? Some reports I've read indicate that the frequency stability issue is only a problem if you are running narrowband data modes (like FT8, FT4, etc.) on 1200 MHz.
As for IC-7610 vs. FTdx-101, I can't make a comparison. I will say that I've had my IC-7610 for about two years. I've had absolutely no issues and the performance has met my expectations. My Icom HF radio transition has been IC-746Pro to IC-7600 to IC-7610 and they keep getting better with every step I've made.
