Balun
ToddWilkinson
ScanMN
I'm new to Baluns, Im using it on vacation, where does the ground go off of the Balun?
majoco
Stirrer
New Zealand
Baluns are usually used to connect a BALanced antenna to an UNbalanced coax cable up at the top - the coax cable is normally used with the correct connector to the radio and is therefore properly joined to the ground..
PDXh0b0
Woodland, WA
Depending on your use,
Good read
I use one with two equal elements as a dipole
Frugal radio has a vid on YouTube recycling an old extention cord for an hf dipole
ToddWilkinson
ScanMN
Good read
Thank you, may I ask how long??
