Baofeng BaoFeng BF-F8HP: enter frequency below 100
nd5y
Wichita Falls, TX
It can't receive below 100 MHz except for the FM broadcast band from 76-108 MHz.
If you unlock it then you just have a box with a LCD display that will show ay frequency but it still won't receive very far outside the frequency ranges it was designed for.
L0NGMAN
Tbilisi, Georgia
That's nice, but I'm pretty sure the HW doesn't support anything outside what it's spec'd for...but I could be wrong. Or at least not far from what it's spec'd for.
Is it possible to somehow check if HW is capable to receive 30-300? I assume this radio is a pretty popular model, maybe there are some tech specs for it or does someone know about it?
L0NGMAN
Tbilisi, Georgia
It uses the Auctus AT1846S transciever chip.
Google that and you should be able to find specs and data sheets.
Looks like that chip supports only 134MHz-174MHz, 200MHz-260MHz, 400MHz-520MHz ranges, am I correct?
Specs I found there: https://img.ozdisan.com/ETicaret_Dosya/500549_6108302.pdf
And an additional question, what mobile transceiver should I buy to have all frequencies in 30-300MHz VHF and 300-999MHz UHF ranges?
L0NGMAN
Tbilisi, Georgia
Well, 30MHz to 1GHz transmit and receive... that's the easy way to do it. If you can get it. There's a reason why everyone can't get one.
"If you can get it" - what do you mean? Is it restricted by law to have such transceiver? Or, its related to money?
