Baofeng Baofeng BF-H6
WSurette
Just purchased a Baofeng BF-H6. Can not connect with Chirp using Tidradio TD-H6 or Radiodity GA510. The radio will no even respond. Correct comport confirmed. Factory Software appears to freeze after initial handshake.
BaLa
4GRC+83; Temple, TX 76502
Same problem.
I was getting ready to rip my hair out.
All the searches I did said it was a Driver issue with the cable.
Pretty sure that was NOT it.
Some other stuff I found said cable might not be seated correctly....After messing around with that. That also seemed unlikely.
Go to Radioddity download the Software/CPS for GA-510.
First one I tried was the new one and it worked.
Software is a ***** to use but whatever.
