Baofeng Baofeng Cable
rrpilot
Serenity Valley, Hera
It's been forever since I've needed to reprogram my UV5R, my new computer is Windows 11 and I see that the old cable isn't compatible with it.
Does anyone have a solid link to purchase one?
I've done some window shopping but it's not always apparent exactly what you're getting, even on Baofeng store.....
Thanks in advance.
merlin
DN32su
You just need to install the drivers. Baofeng cables use prolific chip drivers. Usually Win 10 and 11 have these drivers, If the cable is not recognised, then update the drivers.
mc48
Monroe County, NY
There are no new drivers to use the old cable, the Prolific chipset is obsolete, the new cable will need an FTDI chipset.
I got mine on Amazon from Vally Enterprises.
Project25_MASTR
Monitoring
Texas
The programming cable driver solution is to buy a serial programming cable instead of a USB programming cable.
@Project25_MASTR my computer doesn't have a serial port...get a quality (i.e. BrainBoxes, IOGear, TrippLite, etc) USB-to-RS232 adapter and use the vendor supplied drivers...you'll never have another drive/radio programming cable issue again as long as you are dealing with radios that use serial signaling for programming.
  • Like
Reactions: BBI
