Baofeng Baofeng DM-1701 physical connection issue Windows 11
JustinWHT
That it was a DR-1801 was revealed late in the thread.
/edited for mistyped correction
DR-1701
varagold
Grenoble, France
Nope, there is no DR-1801 mention, anywhere.
It's a common problem we have on the OpenGD77 forum, as Windows installs/updates the wrong driver, and that breaks the DFU mode for such radios (we need it for the firmware update process, not the codeplug reading/writing, as it's done using the serial com (ACM)).
a727469
Maine
Correct. I have never seen a dr-1701 and my dm-1701 cable does not look like the picture. Also in the description of the pc001 it states”Compatible Model (Note: It does not work with most DMR radio!!).”
a727469
Maine
JustinWHT…No problem. We all get confused on some things😵‍💫 just wanted to make sure everything was clear…thanks!
n8zcc
Oakland, Michigan
You may need a different cable with a new chipset, Windows 11 would not recognize my old cable to connect to my UV-5R.
I believe the new chipset is FTDI but verify if you order a new cable. Old cable had PL-2303 chipset.
^^^^^ That is what I also discovered. You need a cable with the FTDI chip for Windows 11 support. It seems, from what I've read, there is a sea of programming cables with counterfeit chips and Windows 11 can detect them and refuse to work with them. Counterfeiters have met the challenge by providing older driver versions with their bootleg chip but Windows 11 updater will catch this and reinstall the current version (of course they don't mention this in their Amazon product listing). It is aggravating because even the legitimate programming cable I bought from BTECH years ago is now flagged by Win11 as counterfeit.
I simply paid the $22 for the BTECH cable and away I went.
