Baofeng Baofeng DM-1701 vs.. 1801
N1SQB
Somewhere On Earth
I'm toying with the idea of getting one or the other simply just for fun, nothing serious. What I cannot tell is which model is the newer of the 2 and what differentiates them. Has anyone tried either of these? I know Radioddity has them under their brand name. However, I like hearing form the everyday user.
All the videos on youtube are a foreign language.....
Manny
N1KK
I just purchased the DM-1801 at the Orlando, Florida Hamcation. I believe the DM-1801 is the newer.
It took a couple days before the place I purchased it sent me a link for the software.
They also told me the radio is new.
I am new to DMR radios and can't really help with differences between this radio and others.
Still learning. What I can say is I have been getting excellent audio reports in both digital and analog
modes. From what little experience I have with the programming software it appears to be identical
to the GD-77 except the GD-77 has a much higher version and the firmware on the GD-77 is higher too.
The software looks identical to what I an using called BF-1801.
I am searching for any user groups of this radio for tips and mods.
Ken
jronca
Peekskill, NY
I have a Hesenate DM-1701 and am very happy with it, let me correct myself, almost very happy with it. The only flaw to date is the minimum volume setting. Even when set to "1" it is quite loud. There is no adjustments in the setting to fix this either. The radio isflash upgradable so hopefully they will push a firmware update to fix this bug.
N1KK
Baofeng just came out with the DM-1702. 2 versions, with and without GPS.
I like my DM-1801. Its does have a few strange things for example when scanning it will stop on a active channel like it should
however if you manually stop the scanning on that active channel it doesn't stop on the active channel you stopped it on like
it should. You then have to go fine the active channel. I found if I hit the BACK button it displays the active channel then I know
where to find it. On the DM-1801 I am limited to 32 channels per zone. Since my scanning is based on zones that is a limitation.
Ken
N1KK
Just curious if anyone else might have a DM-1801. There has been a lot of talking concerning firmware for mods on
github. It turns out the DM-1801 is similar to the GD-77 which has been firmware wise modded as well as the software
used for it. With any luck this will happen to the DM-1801.
Ken
N1KK
Badjob,
yes, and thanks... I have been following the activities there. I have their latest CPS but I have not tired their modified firmware
yet. I might try the new 2.1.9 firmware without mod
Ken
