Baofeng Baofeng DM-1801
N1KK
New to DMR radios. I bought this radio at the Orlando, Florida Hamcation.
With the help of a local ham I have been able to program it with the 3 local repeaters in RI.
Getting good audio reports for both digital and analog.
Would anyone know of a user group, forum any source of info on this radio.
The software looks identical to the GD-77 HT and I am hoping at the price of the DM-1801 ($54)
there will be plenty of users wanting to try out DMR on the cheap.
Ken, N1KK
KG5TUD
Elkins, AR
Ken, N1KK
What programming cable driver did you use and where did you get it? I have tried to use the ones for baofeng but not working on windows 7 and 10
Sent from my SM-G960U using Tapatalk
KG5TUD
Elkins, AR
Never mind I found the issue but, Has anyone found a way to import from Chirp to the DM-1801?
N1KK
Its my understanding the DM-1801 is not compatible with CHIRP
Ken
N1KK
Are you exporting from an existing DMR radio to importing into the DM-1801?
Ken
w8tz
Wondering how you resolved the software problems.
I am having same issue with Windows 10, error message when trying to install BF-1801something about invalid path. Seems to work on Windows XP however unable to connect to radio. The USB driver is a wireless driver. Maybe I downloaded the wrong one? BF-1801 crashes when I try to connect to radio. I am using the USB cable that came with the radio.
jaspence
Michigan
The cable for the GD-77/Baofeng does not have any hardware in the USB connector. I have the GD-77, and the driver is built into the radio, which requires a cable that looks the same as a standard Baofeng but contains no electronics.
KG5TUD
Elkins, AR
It does sound like you may have the wrong driver. I had to make sure I had the cable connected after deleting the wrong driver then ran windows update and driver easy to get the correct driver.
