Baofeng Baofeng DM1701 Scanning question
m6oef
Morning, Does anyone know why my 1701 would be scanning alot slower than when I first got it? I dont remember changing any settings. Its scanning at half the speed-ish on DMR.
Also another question about scanning a DMR trunked system. Why is it the same DMR ID/STATION will transmit on one freq and TG then when they transmit again they will shift freq slightly and their TG will change. Is this normal?
Ive literally herd the same person a few min ago say something and they appeared to be on (and this an example) TG30000 on 141.20000 dekey and then a few seconds later (because they forgot to say something in their last transmission) be on TG30111 on 141.202500.
Cheers 73s
buddrousa
You are trying to take a CHEAP CHINESE HAM RADIO and scan a COMERICAL TRUNKING SYSTEM. You are trying to pull a loaded Semi Trailer with a UGO. Welcome to RR 1st thing is you need to read and learn how Trunking Systems work. But to give you the short answer is yes Trunking Systems are designed to change on every transmission unless the responding user keys their radio while the voice channel is still active in some systems.
m6oef
But to give you the short answer is yes Trunking Systems are designed to change on every transmission unless the responding user keys their radio while the voice channel is still active in some systems. - Thats all I needed to know. Thanks
GregOH
New Phila, OH
Maybe a side key was pressed with the PTT when that radio was transmitting and the channel was changed?
m6oef
I have no idea. I even re uploaded the firmware and blank codeplug. The radio it still in the same frequency range i put it in to scan.
Falcon9h
Cheers 73s
That radio doesn't do trunking. Conventional DMR only.
