Baofeng GT-3TP
wycacher
Cheyenne, Wy
Hello all,
I just got a Baofeng GT-3TP mark iii today. I am having some problems programming in repeaters for my area on 70cm. The input of the radio will only allow me to enter up to 440.995, and not any higher. I have looked around and have not found much on this. Anyone out there know a fix for this?
Thanks in advance!
DickH
Hello all,
Thanks in advance!
The CHIRP program should allow you to set the freq. limits.
DickH
I just found this on Amazon.
"Frequecy Range: 65-108 Mhz (Only commercial FM radio reception), VHF: 136-174 Mhz (Rx/Tx), UHF: 400-520 Mhz (Rx/Tx). Note: Factory defaults frequecy is 140-150/430-440MHz (8W Output), please reset the radio to reach 136-174/400-470MHz or program it to reach 470-520MHz (The software is the same as GT-3 Mark-II)."
DickH
Something you might find useful.
In Freq. Mode, you can enter any two freqs. and they will be scanned automatically if menu item 7 (TDR) is ON. The two freqs. are independant of the ones you put in Channel Mode. For example, I have 19 fire freqs. in Channel Mode that I can scan. Two that I often want to hear I also put in Freq. Mode so I can scan only them.
