Baofeng Baofeng GT-5TP
Bob1955
Eastchester, NY
So I downloaded CHIRP, had a friend of mine take remote control of my Dell 2320 computer and he put in (14) police/fire frequencies with ctcss/dcs in receive mode only. He then got tied up on a call. How do I get this transceiver to scan the frequencies that I put in? (I know the menu button controls mostly everything on this Chinese transceiver. Am I missing something? I even looked online too. It will do a search within a range but not scan what I put in. When it downloaded the frequencies, both green lights lighted up on the radio too and this guy that did it for me is a technician too.
Have a good Labor Day everyone.
nd5y
Wichita Falls, TX
The GT-5TP should have the same menu structure and functions as the UV-82 series.
Detailed information can be found at UV82 - Miklor
You start scanning by pressing and holding the *SCAN key for more than 1 second.
nd5y
Wichita Falls, TX
If you didn't see the key (on the keypad on the front of the radio) labled SCAN and didn't read the last line in post #2 then I give up.
belvdr
No longer interested in living
To be fair, you said it "should have the same menu structure and functions as the UV-82 series" in post #2. Scanning through the UV-82 series and UV-82HP manuals, I don't see any mention of a scan button, but given they are PDFs of an image, it makes searching impossible so I might have missed it. It does mention it on the website you linked to though.
I agree with @Bob1955 that these manuals leave something to be desired, but I found a video that mentions simply holding the * key to begin scanning. I'm guessing that's what they mean on the website by *SCAN, but it's not clear at all with that nomenclature.
Bob1955
Eastchester, NY
belvdr, when you do that, all it does is take the current frequency and count up on it. The CHIRP program did NOT enter ANY frequencies into memory. I'll just continue to use this as a single/dual watch VHF/UHF receiver until list it for sale. I'm no longer interested in this devise now. Radioditty sent me the programming cable on Friday.
Hope you're having a nice holiday weekend.
belvdr
Sorry it's not working. I'm getting what I can from the manuals but it's a test of patience. Unfortunately, I don't own one of these to provide useful input.
It seems like you have to put it into channel mode first before holding that button, otherwise it scans in VFO mode. From another video, it says to turn it off, hold down menu, then power it on again to switch between modes. Hope that helps.
Hope you have a great weekend too.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
You're on the right track. In most cases, the HT needs to be in memory mode in order to scan the saved memories. When in the VFO mode, the radio would scan up (increasing the frequency by the selected step setting) or down (decreasing by the selected step setting).
Bob1955
Eastchester, NY
belvdr, I don't know how to THANK YOU so much for your message to me yesterday at 7:41pm on 9/1/19. I did exactly when you said in your message and all channels are stored in memory with the CTCSS/DCS that was programed in with CHIRP software. Now, how do I get it to scan the above channels in memory and ONLY when you have time to answer this question?
belvdr
After you get it into channel mode, I believe holding the * button will now scan the channels.
