Baofeng hp differences
Blackswan73
Central Indiana
Difference between Baofeng F8tp, and F9tp. Hardware, software, firmware? Compatible accessories, batteries etc.?
toastycookies
the far east
do not get the f9v2 it's just a rebranded f8hp
they are share the same batteries, accessories, whatever.
the f8hp is 8 watts instead of the normal 5.
there really isnt much difference between them.
have you considered the UV-82 ?
Blackswan73
Central Indiana
Looked at it. Was interested in the tri power. Only use what you need. I am about 10mi. From a repeater. It looks like the f9+tp is not backward compatible with extent d batteries etc. of the 5r series
toastycookies
the far east
Looks like a BL-5 battery to me.
www.amazon.com/Pofung-Baofeng-1800mAh-Stock-Battery/dp/B00NQNICVW
This BL-5 1800mAh 7.4V stock Li-ion battery is specially designed for Baofeng UV-5R, UV-5RE, UV-5RA and Pofung UV-5R, UV-5RE, UV-5RA radio.
extra couple of watts is not going to make that much of a difference.
a good antenna will make a MUCH bigger difference.
Blackswan73
Central Indiana
I bought the f9+to and the UV-82. I like the reviews on the 82. I just hope it can hit a repeater 10 miles away. I will find out.
toastycookies
the far east
make sure you get the FTDI programming cable.
and i would also recommend a quality antenna.
that is going to make the largest difference on these radios..
although I do not know that exact scenario, i find it hard to believe you would not be able to hit a repeater 10 miles away.
AL6F
North Pole, Ak
Baofeng BF-F9V2+ real or knockoff
I have had a BF-F9V2+ for about a month now. On the inside it says it's Baofeng, it has that on the front as well and came with a Baofeng BL-5L 3800 battery. I added a Nagoya NA-771 ant. So far it picks up just fine. Repeater is about 20 miles away. I programmed with Chirp, piece of cake. Not sure where the Pofung versions are coming from, but mine says it's all Baofeng. I have been told it's just a knock off, but I don't have the version that it is supposed to be a copy of, yet, it's in the mail and should be here in a day or two.
