Baofeng DM32UV Production Runs
Dewey
The battery latch on my AT-D868UVE has finally given up after eight years. While I know it's not an AnyTone, I think I'm going to pull the trigger on a Baofeng DM32UV. Looking around Amazon, it's really hard to tell the difference between the $50+ DMs up to the $100 DMs, because it looks like a lot of the sellers will use each other's pictures or specs that are just not accurate.
I am trying to make sure that I find the latest production run as possible to avoid things like what I've read about the earlier HR vocoder run models. (I've read that the HR vocoder is a little more locked down than the "common" vocoder). So now I'm trying to see if there is a way to figure out the production runs. I've also read that one improvement is that newer DMs have a smaller display bezel (I can't see a bezel difference in every picture that I've seen). Are there other things that I can look for? I really like the all black models, but one of the things I've read is that the current production runs are the black and green models. So any help in being able to tell the newer production runs from the older production runs would be greatly appreciated.
