Baofeng BAOFENG UV-82 PTT BLOCKED. AND IT MAKES A BEEP.
kim33
Good morning,
I programmed a baofeng UV-82 and loaded the .img from another baofeng. Now the ppt is blocked and can not emit the voice. I need the .img to reset the baofeng with the chirp software. Does anyone have this file or know how I can reset the software.
The reset All does not work and pressing the ptt key + the light button + the lock button and turn on, does not work either.
Thank you,
nd5y
Wichita Falls, TX
If you didn't download and save the original out-of-the-box image before you programmed the radio and then you uploaded an image file from another radio with a different firmware version then you might have ruined it.
If you know the original firmware version there may be an image file for it here:
If not then there is probably no way to fix it.
kim33
Thank you very much, I clicked on 3 and turned on the baofeng, and the version it uses is US2S25. And it is not on this list.
