KPG-89DN and TK-3180 Question
N1SQB
Somewhere On Earth
Good morning!
I finally got around to programing my new ( to me ) TK-3180 UHF portable. Being new to Kenwood software, I am in need of some help. First of all, I am new to Kenwood, but not to commercial CPS.
I managed to program the portable, read/write is fine. One thing that I noticed, is that the radio stops on a channel, you hear audio etc.. but the display only shows the channel # on the upper left corner, and the zone name, no channel name. Coming from Motorola, I’m used to seeing the channel name once scan stops. Is there a setting I’m not programming right?
Second issue: when I hit a button to toggle light on, only the SABC and the 1,2 keys light up.
I have a suspicion that someone rebased this radio wrong. It may have been a K2 and a K3 full keypad was installed. Does this make sense to anyone? If this is the case, do I need to get a new K3 board?
Manny.
kd4efm
EL98 Florida
so that means BLANK CHANNEL (no info) and you have the key menu set so it's mimicking a 16 channel per zone. (top switch)
Lights, check key assignment for this. If full keypad is off, this would happen.
I have to load 89D to get you photos. More to come, or someone will also post it.
N1SQB
Somewhere On Earth
Ok, I'm not sure I follow. I checked "key assignment" and it is set to 12 key. As far as the BLANK CHANNEL issue, I have 10 channels programmed in what looks like a 16 channel zone. Are you saying something needs to be changed?
kd4efm
EL98 Florida
Key assignments
If you take the stoper out from under the Channel knob, then you will roll back to channel 1 AND it will skip over empty channels in the zone
kd4efm
EL98 Florida
Note: I have sold of my x180 radios years ago when NX series came out
but what you're saying would be true as noted if you have 16chl/zone configured, it would give a tone if you skip a channel like 1,2,3,4,5,x,x,8,9,10,11,12,x,x,x,16
(x being blank)
N1SQB
Somewhere On Earth
YOU GUYS ABSOLUTELY ROCK! I am good to go. I was mistaken in the zone text length. I set it to none and now I'm good. I cannot thank you both enough.
Now the only issue I have left is that the number 1,3 keys light up but not the rest of the numbers. I still cannot figure that out.
n7maq-1
Oregon
You were most likely correct in thinking it was re-cased. The keyboard needs 6 more LEDs. It may need more also but I have not done any conversions myself. I'll ask another tech when he is back in the shop.
N1SQB
Somewhere On Earth
That's what I thought but was not sure. Thanks for verifying that .
I am dealing with one more issue that's popped up now. When I TX on channel 1, it goes to ch-2. So then I tried to receive on ch-1 and it is not receiving. I triple checked frequencies and PL tones. I guess I'll get it right at some point.
AM909
Radio/computer geek
SoCal
It looks like, in addition to the six LEDs, it's just three 390 ohm resistors (R524 R525 R526) on the other (foil) side of the board
