Paco-Jerte
You Member, Member!
Anyone try their new super huge battery pack? I Amazon has it for $38-ish ?
seen them for $23
Yeah sorry it's $24 on Amazon.seen them for $23
I want to get up to 512Mhz on my DM32 as well. Can you show what exactly you did to get it to work?After twisting and turning I took my 30% refund offer and kept my portable pig. My radio had .046 firmware so I obtained 0.47 and saved a copy, I hex edited the CPS and my code plug to lift the uhf band up to 512mz and updated firmware. In the radio it reports as .048 go figure ….. after multiple read and write errors , it just wouldn’t complete the process reliably, I ticked some boxes and made some adjustments TOOLS > EMBEDDED INFO and things now seem to work correctly read and write complete. I decided my most regular use case is monitoring a large T3 system of a major airline during work hours and so listening to air and land ops combined works, not seamless or complete but it works. I've been using Hytera for years now and so the only downside with this turd and was always the case with Motorola & Tait as well, limited scan members (Motorola 16 Tait 50) and having to program both slots individually (Motorola and Tait). Problematic for this particular T3 12 frequency site. Hytera psuedo trunk listens to both slots so I‘d have effortless coverage of the entire site in a single 15 slot scan list. DMR decoding is smooth and consistent, it sounds quite good and analogue U/V TX RX is fine. DMR monitor is useful. This would be a frustrating first venture into DMR for a new learner with all the built in quirks and software shortcomings currently but it does work …. eventually. I’ll keep messing with it and watching developments in the community as this is my first and likely only CCR purchase, a curiosity purchase after years of commercial LMR options.
Maybe a bit more than an inch. Couldn't find a ruler this time of night.That battery pack looks as if it adds 1 inch to the height of an already tall radio.
It's not bad. Can't say anything else about it. It works and capacity is more than the standard battery.Anyone try their new super huge battery pack? I Amazon has it for $38-ish ?
In my absence, the advice given "follow the instruction posted earlier" is the simple answer, you really cant make it it much simpler then that. There is a multitude of modified firmwares and hex edit mods orginating from a Russian forum also thats freely available and easy to interpret with any free translator. I'd suggest initially using the basic hext edit - frequency range limits only until you've learnt all the quirks of this radio and you are confident the unit you own is functioning correctly initially from the factory. Then go for broke and add all the "hacks". Having said that, this is a relaitvely easy radio to "unbrick" should you do yourself a mischief. Enjoy.I want to get up to 512Mhz on my DM32 as well. Can you show what exactly you did to get it to work?
Long term reliablity? Beats me. Chinese batteries and all the jazz. For the price, stack them deep if one poops the bed.
FYI, do not order the single, UV-32 3800mah battery from Amazon. They have mislabeled the packages. I ordered the DM-32 3800mah battery x 2 kit and they ARE the correct batteries.I ordered one from Amazon the other night and they sent me the friggin' UV-5RH extended battery despite my order of the correct DM-32 battery. /sigh
Select VFO A or B; In the radio menu, select Settings/Channel Set/Channel Type/Digital. I think you can also set a programmable button for Channel Type. Alternatively, you can create separate memory channels as either digital or analog.I received a DM recently, and have not been able to figure out how to engage digital VFO mode. I don't see it in menus or key assignments, but figure this is one of those things of hiding in plain sight. What am I missing?
Ok. That worked. Thank you. I thought I looked at that menu.Select VFO A or B; In the radio menu, select Settings/Channel Set/Channel Type/Digital. I think you can also set a programmable button for Channel Type. Alternatively, you can create separate memory channels as either digital or analog.
Even more so now that our favorite Russian Baofeng hacker released a version of the firmware that disables the ALPU self-check. Guy is talented.Having said that, this is a relaitvely easy radio to "unbrick" should you do yourself a mischief. Enjoy.
Baofeng downloads pge at DM-32, there is a certifications approval from a 3rd Party Certifier.I think you have to download the zip file, unzip, and its the last two docs.Done on YouTube, and extremely low SE. Baofeng finally has a decent radio for an CCR!
