Baofeng Baofeng UV5R reflash?
PDXh0b0
Woodland, WA
Stuck? I love my Quahseng uv-k6
nd5y
Wichita Falls, TX
Is there anyway to flash the UV5R with the ezgumer firmware?
No. The UV-5R and UV-82 type radios have a one time programmable microprocessor.
Even if you could reload the firmware it would be stupid to try to load the firmware written for another totally different type of radio. Even if the software used to load the firmware recognized the wrong radio and allowed it you would likely end up with a brick.
merlin
DN32su
No. they are very different radios than Quansheng. Even if possible, the firmware is much different. (different CPU cores)
I have both the Baofeng UV-5R and the UV-K5(8). The K5 simply beats the pants off the 5R, more power, more otions, open source firmware that can be reflashed in minutes expanding and improving over stock. For $35,, buy two.
The K5 8 is the hottest ticket in the ham and scanner arenas in a long time.
Just stock it is like a 5 band radio from 136 to 600 Mhz, and receive down to 50 MHz. Pre canned weather and air band.
Cheap Chinese junk ? yep, but it works.
merlin
DN32su
Off topic question @PDXh0b0 out of the box it does UHF MilAir? And, if so, how is reception? Thinking about getting one before airshow in a few weeks.
Yep it sure does, and will transmit which is a very bad thing. The RX is better than the Baofeng.
That is another topic, transmitting ouside amateur bands that will violate FCC ruels and even federal laws. It is on you if you do.
Stock amateur bands are 2 meter, 1.5 meter, and 70 Cm. Power on 1.5 meters is down a bit, but a tri band antenna,it is usable.
