Bartholomew co highway
cdgates
Columbus Indiana
I have listened to 151.085 and receive nothing, I have a friend that works for them, they use radio all the time, I have a idea they have moved to a trunked system of some kind, but I don't know?
cdgates
Columbus Indiana
Yes have a sds200 with the DMR upgrade. But that kind of lost me, 151.085 was a standard repeater output frequency, could that same frequency be used for DMR now? I have never programed a DMR frequency
cdgates
Columbus Indiana
Yes, I can't find it anywhere, I even asked the people that service the system, they only told me that it was a single frequency that was in the Columbus system, and would not tell me anymore. At one time I sold radios into the repeater systen, I don't know what the big secret is, I would like to listen when we have large snow like we do now.
west-pac
In your scanner, program 151.085 as an analog FM channel with no PL tone. If you hear digital/computer noise then you somebody is operating DMR on that frequency. It could be County Highway, or it could be your Sheriff's Dept.
First you have to figure out if there is radio traffic on that frequency, then you can figure out how to decode it.
cdgates
Columbus Indiana
I hear no siginal of any kind on 151.085, i.have plugged. It into two scanners and i.hear nothing. It's only my guess that when the county went to trunking the highway dept is in some way in the mix of things.
west-pac
Did you program your scanners by hand, or did you program via Radio Reference?
Edit: The information on Radio Reference is not complete. You're not going to hear anything if you are programming your scanner with software that gets its data from Radio Reference.
cdgates
Columbus Indiana
I did most of the programing through RR WITH SANTINEL softwear, I had a friend that has a 200, he did most of the programming at first, he could not find BARTHILOMEW COUNTY HIGHWAY himself, i have been trying to find it for about six weeks, I thought if I put this out on this form I may get lucky and find someone that has found it. I was also thinking becouse I ran a two-way radios business in the past they would give me the information? Before trunking came on the market I got out of the business, I know they are using sompthing, When I seen this frequency listed as DMR it was a surprise, but I did get the DMR update from Uniden, I might note i found some frequencies listed as DMR that worked before I bought the DMR code, I have no idea how DMR works and if it's in someway mixed up in a trunking system. When I sold radios, the 151.085 repeater was used at night sometimes by the sheriff dept and also used by other county people, like code enforcement, and other county likewise county employes.
west-pac
Right. So apparently the 151.085 repeater was switched over to a DMR repeater that can be shared by many users.
The issue is: it takes more than just knowing its "DMR" to listen to it.
DMR has 3 parameters that need to be known in order to program a scanner to listen to a specific user.
You need to know the (1) Color Code, the (2) Slot, and the (3) Talkgroup number.
On the Bartholomew Co listing it shows the Sheriff's Dept using this DMR repeater utilizing a Color Code (written as: CC) of "4".
The Slot (written as: SL) is an asterisk, meaning someone did not know which Slot they operate on. There are only two options for Slot: Slot 1, or Slot 2.
The Talkgroup (written as: TG) is an asterisk, meaning someone did not know which Talkgroup they were using.
In the programming softwares, an asterisk tells the scanners to search for anything that it hears.
On the County Highway listing, it just says DMR. It doesn't list a CC, SL, or TG; and it doesn't list any asterisks either, so I'm not sure that it's even trying to search 151.085 for any DMR signal at all.
You said you're not hearing anything, but it may be that you haven't programed enough information into the scanner to even attempt to hear it.
So, you're back to square one. To verify that there is DMR radio traffic on 151.085, you can program that frequency into your scanner as an analog FM channel. If you start hearing digital/computer-type noise being transmitted on that channel, then that will tell you that there is, in fact, digital radio traffic on that frequency.
(or you could just skip to the following step)
Program in the Sheriff's Dept's DMR channel. It's the same frequency, with CC:4, and asterisks for SL and TG, meaning it'll let you hear any Slot and any Talkgroup that comes across that frequency.
If the Sheriff's Dept uses SL: 2, TG: 101..you'll hear it.
If the Highway Dept uses SL: 1, TG: 301.. You'll hear it.
If the Health Dept uses SL: 1, TG 116.. You'll hear it.
west-pac
I saw that somebody added county highway to the Columbus P25 system. If you update your database from Radio Reference you will be able to select and add it to your scanner from your software.
cdgates
Columbus Indiana
We updated the information on Bartholomew County Highway to the P25 system and it worked the next day and that was the end of the reception, now I am trying to unerstand what went wrong, was the system changed again or did I do sompthing wrong on my sds200, this really has me puzzled?
INDaviation
D1 Hater
The 317
It could be that the control channel rolled to one you don't have programmed, or that they just don't talk much outside of major snow/ice events.
cdgates
Columbus Indiana
I am sure they have radio traffic, any ideas how to find them? It's almost like they have seen the system show up on RR, and changed it, it worked well for one day then it's gone??
