Base Antennae Question
Any recommendations for a Base Antennae (one brand over another)? Looking to install in attic or on patio for a scanner.
res2cue
Two that work realy well are the "Scantenna" or the Radio Shack 20-176.
Both work well to 400MHz then the scantenna works a little better higher up that.
If going the attic route becareful with the scantenna it is almost 5' tall.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You also might consider the Niljon, or if you have the vertical space, the Diamond discone. If you like a little homebrewing challenge, see the vertical dipole project a couple of topics down.
There are several good ones - it would help to know your interests...73s Mike
