the 'charger' circuit is simply based on a timer. It dos not take into account how much charge (if any) the batteries require, You set the time for charging in the menu. But if you set it for, say, 6 hours charge time (in the Menu, under Settings/Battery Options/Set Charge Time), then the scanner will charge for six hours (when turned off) even if the batteries are already completely charged. Your best option is to charge batteries in an external, 'smart', charger, that uses a proper rate, and ends the charge when the batteries are fully charged.
