Battery Issue?
I have a 396XT that I have had for about 4 years. Over the summer it stopped working... It will turn on but after 5 seconds it will shuts off. I plug it in and it won't help, I have changed batteries 3 times and no change. I have charged all the batteries in both the scanner and in a battery wall charger and still no change.
The scanner has sat for a few months, last week a buddy upgraded scanners and gave me his 396xt and some of his old 396xt stuff, batteries where included. The batteries are the original ones that came with the scanner 6 years ago. His scanner worked fine, so I swapped out his batteries and throw them into my non-working scanner for ****s and giggles and it came to life, The batteries (all 3 sets of "New" Rechargeable) that were in my non working one went into his working scanner and did not work. If I put the 3 sets of new rechargeable batteries in anything else in the house (tv remote, etc) they work.
I'm not understanding whats going on. I now have 2 396xt's, But only have "Working" batteries to operate one. I have read on some other post about what batteries everyone is using, some order from online companies, some buy regular rechargeable batteries from the corner store... I have done both with no change.. So I'm in need of battery idea's ASAP...
traumacop
Newark, Ohio
I used rechargeable energizer from Walmart in 2 396Ts and a BR330T and have never had a problem.
Sent from my Nexus 7 using Tapatalk
N8IAA
Fortunately, GA
Four years, and probably charging in the scanner. Hmmmm, could be they're no good:confused: Get a Maha charger, and charge the batteries outside the radio. You'll get more years too. You'll keep those newer batteries longer.
Larry
I charge them outside the scanner and I even tried inside the scanner when the issue started to see if it was my charger or a scanner issue. I have bought 3 different brands of rechargeable batteries and none of them have fixed this issue.
04Z1V6
Castle Rock, Co.
Do you have your battery charge time in the programming set? Do you have the micro switch in the battery compartment set?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
It really sounds like the batteries are shot, but I have one question. What external charger are you using? A lot of chargers can't charge 3 batteries, they need multiples of 2.
Just a thought.
rbm
Upstate New York
I use only 'low self discharge' (LSD) batteries.
They're much more dependable.
I currently have more than 60 AA cells (and around 40 AAA's) and in the last 5 years or so, I only had one that went bad on me.
Before that, the 'non-LSD' batteries used to fail often.
I finally just threw them all out and stick with the LSD cells now.
The links show two examples. I have mostly Eneloop cells but also some Kodak, and some Radio Shack cells.
They've all been equally good.
The package will specify 'PRE-CHARGED'
BTW, I agree it's best to charge them out of the radio.
Here's a good charger that will Automatically identify AND charge Li-ion, Ni-MH and Ni-Cd rechargeable batteries.
Compatible with:
Ni-MH/Ni-Cd: AA, AAA, C
Li-ion: 26650, 22650, 18650, 17670, 18490, 17500, 17335, 16340(RCR123), 14500, 10440
Capable of charging 4 batteries simultaneously
Each of the four battery slots monitors and charges independently
Shop around for the best price.
Amazon.com: Nitecore IntelliCharger i4 Battery Charger - 2nd Generation: Sports & Outdoors
Rich
Amazon.com : eneloop AA 1500 cycle, Ni-MH Pre-Charged Rechargeable Batteries, 4 Pack : General Use Batteries : Electronics
Rayovac Pre-charged Rechargeable NiMH AA Batteries 8ct, Digital Camera AA Batteries, Rayovac NiMH Batteries, NiMH Camera Batteries, AA Rechargeable Batteries
