SDS150: BATTERY REMOVAL
motorman105
Orange, CT
Someone mentioned they had a hard time removing the battery.
I agree, what worked for me was to grip the 150 in such a way that I could press the installed battery into the scanner while pulling on the release. It worked! It wasn’t easy but it worked. Ugh!
ratboy
Toledo,Ohio
The first time I did it, I used a penny. I Only for a few times, it loosened up, as I expected.
tvengr
Well Known Member
Baltimore County, MD
The battery latch was extremely tight when I first installed the battery. I had to gently use a screwdriver to open the latch to remove the battery. I squeezed the battery cover to the case as hard as I could but still could not open the latch by hand.
