Battery Tester Question ?
bear780ks
Central KS
I ordered a battery Tester it's built by ZTS inc. the Unit i purchased is the ZTS Mini '9R' it's designed to used with 1.2 V & 1.5 V batteries and 9 volt batteries as Well in the Ni Cad or Alkaline form...
ZTS offers Quite a bit of different testers even for the Military). I got the one pictured for my battery testing needs and i like that it puts a load on the Battery..
The Question i was wanting to ask has anyone here on the Forum used one of these tester & what do think of it..
ZTS, Inc. - Pulse Load Multi-Battery Testers™
gewecke
Illinois
Interesting...
Product reviews might be good reading.;)
73,
n9zas
bear780ks
Central KS
Got My New Tester
Got my Battery Tester and i got to say it looks Really Cool like something out of the Future its easy to Operate Just set the positive of the Battery to the positive port of the Tester and use the attached negative Test lead on the Negative end of the battery).
Give it a few seconds and it will show the Results of the Test.. Here are a few pictures i took of it so far.. :D Ra
bear780ks
Central KS
Good Tester Good Batteries
I added another Picture of my ZTS MINI-MBT9R as i mentioned in my earlier Post its working out pretty Good One thing i like it's so Compact it can fit into a Guys Pocket or Woman's Purse if there into Testing Batteries).
It has Pouch that you can put it In but the Guy that Ordered it For me either For got it or Didn't Know one could be Ordered with the Pouch so i will have to get one Later but i do have some things i can put it in..
When i picked up my Mini Tester i also picked up another Pack of 8 Eneloop's that makes my total of eneloops @ 19 :p
Halfpint
Slightly NE of the People's Republic of Firestone
Years ago when I was running a Stereo/Hi-Fi repair shop I ran across the ZTS products at a `Trade Show' and ended up buying my first unit from them for the purposes of being able to easily test and show the condition of a customer's batteries on a `front counter' basis before possibly taking in whatever they'd brought in for repair. (Amazing how many people would come in complaining about their `Walkman', or whatever, being `dead' and not realizing that it was just a case of dead batteries! The quickness of the test, and the flashing lights, was a wonderful tool.
Now days I've got a MBT-1, MBT-LA2, Mini-MBT, and a Mini-MBY9R where I can easily reach that I mainly use for `personal', and sometimes `loaner' use depending upon what the situation is at that time. I usually am the only user of The MBT-1 and MBT-LA2 units while the MINIs occasionally end up getting used by either one of our children or `loaned' out to close friends depending upon what types of batteries that might need testing. (One of the amazing things about the `loaning out' of the MINIs is that after they've been used a couple 2 - 3 times I've gotten questioned about where the borrower can get one of their own! I've even had some of my children's teachers ask about getting one or two units for use at school!)
Now... These testers do not actually give one a voltage but rather it is more of a `under load' Quality that they test for unlike most of the `meter type' testers one can find. And along with the various `battery types/sub-types' they have provided tests for they have a processor that runs certain tests specific to those `types/sub-types'. (The MBT-LA2 actually goes even futher in that it also provides user selected tests for voltage and current capability because it is used for `storage' type batteries one might find in use in UPSes or automotive applications. [I just recently used the MBT-LA2 to diagnose a problem with a battery in our snowplow truck. It would start the truck a few times and then suddenly act completely dead even after being put on a charger. I took it out and put it on a workbench, charged it and tested it several times over several days with both the MBT and a regular carbon pile load type tester. The MBT-LA2 would show it as bad after a couple days of sitting whilst the load tester wouldn't do so until 3 or 4 days later. After I went and took the battery in to the battery shop to get a new one, one of the `backroom guys' decided to do an individual cell test and discovered that the bad battery had one cell bad and a second cell on the way out. Apparently the load tester would just run up to the set load, take a reading and then shut down and call the battery good!] Oh, BTW, the MBT-LA2 will test more than just your `run-of-the mill' 6 & 12 batteries. It'll handle 2,4,6,8, & 12V batteries with AH ratings of up to 200AH something `carbon-pile' load type testers don't do very `gracefully' or without a lot of calculations being required.)
Now the MINI-MBT9R model does have it's limitations in that it basically is for use with Alkaline and NIMH batteries. The MINI-MBT doesn't do NIMH 9V batteries but instead replaces the NIMH 9V test with the ability to test 3V Lithium (CR123, CR2, & CRV3) batteries. Unless one uses 9V NIMH batteries quite a bit the MINI-MBT would probably be enough for general uses.
For people who find themselves having to deal with a lot of batteries the ZTS products are worth taking a close look at. They even have a couple `Military' use versions of the MBT-1 style tester if that is what one has a fair amount of `contact' with.
bear780ks
Central KS
Review and Were to Buy
The more i use my Tester and the More i Read on them i Like allot i want to get the Big one as Well
I will provide some Links on here of some Reviews that ones have done With these Testers The biggest thing i Like of these Tester's they're maid Right here in the Good ol U.S.A. not some Overseas Manufacturing plant..
Here are some of the links i provided:
ZTS MBT-1 Battery Tester
ZTS Battery Testers: Useful and Accurate Tools
ZTS Product Reviews
And here is some of the Places you can get one of these Great Testers :D Ra
ZTS's has them for Sale or by one of there Authorized Retailers..
Where to Buy - North America
