BC 346xt Freescan
zynx
Kilmarnock, VA
Freescan returns a message that the scanner is not recognized. I've read everything I can find regarding Freescan, reverified my port setting, but still no communucation with the unit. What small detail am I over looking?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Several possibilities here, but let's eliminate the obvious - how are you connecting the scanner to the PC? If you are using a USB-serial cable, you must load up the drivers before connecting the cable. In addition you should check Device Manager to see whether the COM port the drivers allocated is really available. This topic is discussed here...
Connecting scanners via USB - The RadioReference Wiki
Next did you configure the port on the 346XT? That's discussed here...
Freescan - Connecting Scanner to PC - The RadioReference Wiki
and finally, make sure that Control channel output is off....which is mentioned at the very bottom of the above article
Mike
zynx
Kilmarnock, VA
Now I get it
Mike, thanks so much for your suggestions which made me rethink it everything. As it turns out either I can't read or my old time PC thinking got in the way. What I did was to use the slave / master option clone selection. I did not need to do, as you know.
This radio has this boy fairly steep learning curve at first. Whew, I made it a bit further up the hill. Now the fun begins.
Thanks Again,
Jim
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Jim, the links in this article are set up for folks just getting started with the DMA radios. At the bottom are the links for the Easier to Read guides- don't even think of using the Uniden produced mess.
Program your DMA Scanner - The RadioReference Wiki
No matter what software you use, you really need to understand how DMA works before you get started. On that same note, be sure to back up your current config before playing around. That way you haven't lost your starting point...Mike
zynx
Kilmarnock, VA
Right on the money.. again. I spent a fair portion of my work day (self employed thankfully) pouring over that subject and creating a worksheet to plan out my systems.
thanx again.
