BC-796 change scan direction ?
LarrySC
Greenville, SC
Where in the manual is changing direction of scan mode? I know it should be simple but I guess it went right past me.
rdale
Lansing, MI
Don't have one but just curious -- why would you do that?
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Hello,
I don't know where it is in the manual, but while scanning conventional frequencies, I use the VFO to change scan direction.
HTH
Dave AKA The Tripzter :shock:
LarrySC
Greenville, SC
rdale, robdale?, I didnt say I wanted to do that. The question is to help someone who has a scanner running backwards. I will try the other post, however.
DJ88
Brick Twp., New Jersey
On the 785D you turn the VFO knob counterclockwise and the arrow will change to up or down. It's probably the same on the 796.
LarrySC
Greenville, SC
Thanks everbody. I called the guy and told him how to turn it around. I've not had that to happen to me and couldnt figure out how to correct it. Maybe that why I've still got some old Xtal scanners in use on special freqs.
