Just from a safety view, am I right that if I accidentally used alkaline batteries with my 125AT set on NiMH that the worst that could happen is scanner circuits could/would be damaged?
The UBC125XLT charging circuit appears to be current limited by an 8.2 Ohm 1W resistor from the USV 5V supply.
USB power at 5V. Battery voltage is 2.4V nominal so current = 320mA. Resistor dissipation = 0.8W
USB power at 5V. Battery voltage at 0V nominal so current = 610mA. Resistor dissipation = 3W
With those basics it is a little more complicated as far as I can tell. There is a transistor to switch the charging On/Off according to the timer. There is also some other monitoring circuitry driven by the processor. This may or may not allow for over current detection. Had to tell.
It the case of putting an Alkaline battery in on the NiMH setting then when 5V USB is applied my UBC125XLT comes up "Battery Error"! and no charging current appears to be present. If I put just one alkaline battery in the on a digital volt meter the current is modulated and on an analog meter approx. 300mA.
Removing batteries and shorting delivers no current.
So the circuits seem quite safe.
