BC125AT Modulation
andy51edge
Somewhere in North Texas
Hello I was looking into purchasing a Uniden BC125AT and I was wondering if it was possible to change the modulation of the radio signal independent of frequency. (for example if I was listening to 123.45 MHz and I wanted to change the modulation from AM to NFM, again this is just an example I'm not sure why someone would be using NFM in airband). I have a BC346XT and it is very easy to change the modulation independent of the frequency or I can just put the modulation into an automatic mode. Can this be done on a BC125AT easily and on the spot?
UPMan
In Memoriam
Arlington, TX
Yes. While on the channel, press FUNC+PGM, then change the Modulation setting for the channel.
