Analog Signal Chasing
Ubbe
Stockholm, Sweden
Is there a scanner that could make this activity easier I would be interested to hear more
As already mentioned the TRX-1/2 can be used. They never open squelch immediately on a carrier but first check what type of signal it is, which can be annoying, but in your case will just stop briefly on a signal without unmuting and then continue to search for only analog signals.
But they are limited having only one search range and doesn't use a bandplan that can be edited but supports several different countries that hopefully will match.
Some scanners have a sound squelch that also works as a data squelch but will always let you hear the datasignal for one or two seconds.
Best way for you would probably be to create scan tables, one range with a unique step size in each department and one VHF or UHF band in each system, for your 436 and/or SDS100 to match the exact bandplan used in Australia and sit and monitor for an hour or two and permanently avoid all data channels you can hear.
I set a negative delay to -10sec so it will continue to scan even when the scanner finds a new data channel. Then I import the recorded files into Universal Scanner Audio Player to analyze the result and any data being decoded can then be manually set to avoid in the scanner or in Sentinel. After a while all data channels in your area will have been found and avoided and the recorded files on the SD card will only have analog channels that then can be set to a normal delay of +10sec.
I would recommend to not use a SDS100 to search for unknown frequencies, it is too unreliable as if a signal are -80dBm or stronger it will, due to intermod issues in the scanner, also be found at other frequencies that are not the correct one and will confuse you. I only use my BCD536 and sometimes the UBCD3600 when doing searches for new active frequencies. If you have ProScan you can probably connect an extra audio cable to your 325 or 996 and also use that to record files. USAP also supports Icom files so that could also be an option if it can be programmed to follow your bandplan.
/Ubbe
W3DMV
Gettysburg, Pa
The Icom R-8600 has a function called "VSC", voice
squelch control which performs this function. I use
it all the time when looking for analog signals while
searching...
pb_lonny
VK7AAL
Tasmania
searching...
I think the R6 has the same, I am not sure how "well" it works.
VK3YMML
VK3VSN / VicScan Forum Owner
Melbourne, Victoria
FYI all, I am in Melbourne, Australia so we don't have any transmissions in the 700-800mhz band except maybe for Tetra.
I am using the Frequency Search function of the scanner and mainly using the 400Mhz - 510Mhz range which is used by many commercial business however as mentioned I am wishing to bypass any digital signals.
The issue with the "avoid" function is that most scanners have a limitation on the amount of frequencies that it can store and then you get the inaugural "Avoid List Full" or words to that effect on the scanner.
Recording the audio would only work if a scanner can be connected to a PC and it registers the frequency that the signal came from otherwise its would not really aid the search.
A Whistler TRX-1 I have checked Ebay and they range from AU $300-$800 and let alone the shipping to Australia so not really a viable solution.
The other option is using a rasp-pi and a sdr which I have however to date I have not located a suitable solution at this stage.
pb_lonny
VK7AAL
Tasmania
I run AutoStore on my BCD325P2 and UBCD396XT a lot of the time, I then scan this system and lock out anything digital. I also run it at times with CTCSS/DCS tone search enabled, if a frequency is found with one of these tones, I know it is analouge.
How are you saving your results? I have an Excel spreadsheet which I update and compare to the ACMA database. This has some logic around the groups / modes and dates, to highlight anything new / interesting.
Have you used the recorder on the 436 or SDS100 much? I use to use Discovery mode a bit on mine, this then gives you audio recordings you can review and see what is being recorded as analouge or digital.
VK3YMML
Melbourne, Victoria
I am using the 436PT to record however I need to clear the card before it reaches capacity. With respect to the ACMA database sometimes you need to alter the distance as some frequencies are filtered out. For instance I came across a new frequency in use in the 505.xxx Mhz range though the matches I get with ACMA currently dont line up with the traffic heard via the frequency. My only thoughts are either its being used by another party illegally and or the transmission power or maybe some tropospheric ducting is in play.
I have a spreadsheet that I currently manage. The SDS100 is currently running a different digital network so that has been sidelined for now. I have other scanners connected with ProScan which I have done in the past however I just obtained a 996XT based on some of the advice I will trial it with the -10 delay and see what impact that has. I will also check on the CTCS/DCS tone option.
Part of this active search is to show that Analog is not dead and there is still plenty out there to find and monitor.
Ubbe
Stockholm, Sweden
You can switch to a 32GB SD card and it will hold up to a month of continuous 24/7 recordings but as you probably don't have a constant activity there will be times when the scanner are silent so will allow the scanner to work unattended for more than a month until the card is full. Using USAP you can sort and filter the logs and instantly listen to all recordings.
As Paul mentioned there's also Discovery mode in some scanners that are supposed to compare any hits to what are already in the database and in Favorite lists and ignore any hits found in those files. It can also avoid an unknown frequency after 3 hits that would prevent getting hang up on data channels as it also has a timeout timer for a recording.
This works fine in any old firmware like a HP-1 but Uniden messed it up in newer firmware (old firmware for 435/536 where initially OK) and it stopped working in that way. Even when all those functions are available still some of them can no longer be used in BCD and SDS scanners and it's only the recording and logging functions that work as they should but none of the compare and automatically avoid.
/Ubbe
bearcatrp
Land of 10,000 taxes
Everything 700 MHz is all P25, 800 will be mixed. If you're near a big city, there's probably a lot of UHF DMR in the area. 450 to 470 should cover most of that but there might be high band stuff in your area as well.
Just tried it with the 26 pro. Picked up about 5 stations I had to temp lock out.
VK3YMML
Melbourne, Victoria
Hi all.
Over the last 7 days I went old school using 4 different scanners and manually searched. Locating 311 analog frequencies.
My plan is with the three 436PT to run each on a different band, each with the current located frequecies.
If I understand correctly, Discovery will check the Programmed DB to see if the found frequency matches?
pb_lonny
VK7AAL
Tasmania
I "think" this only checks against the RadioReference DB programmed, not what you have entered in to yourself. If so, this is pretty "pointless" for us here in Australia.
VK3YMML
Melbourne, Victoria
I will do some research and see what I can find out. Otherwise maybe creating something on a Linux system
VK3YMML
Melbourne, Victoria
Performed a test run with Discovery. So if the Frequency in the scanner database that you have programmed and written to the card, the scanner flags that Discovery Frequency as "Known". If however it does not match then its called "New Found" unfortunately even thought your searching for Analog the system seems to log Digital signals also.
I currently have this running on a Uniden 436PT between 470 to 500 Mhz
pb_lonny
VK7AAL
Tasmania
That is very interesting and a bit different to how I thought it worked. I might need to get another UBCD436PT, as this feature would be VERY helpful for me.
VK3YMML
Melbourne, Victoria
Based on my manual Analog search I put in the frequencies for the 400Mhz range and then also added UHF band as well. I checked the scanner this morning and after 6hrs it had 44hits however a number of those will be digital (P25, NXDN, DMR) it will be interesting to see how things progress today and I will check the log tomorrow.
It will be interesting to see if you can resume the Discovery Session from where you left off or will it start from scratch
VK3YMML
Melbourne, Victoria
I think it creates a new one, with a new date and time.
Ok ...shall see how this all goes otherwise the next option is looking down the road of the Rasp Pi and sdr combo. I have two pi's doing nothing and a few spare sdr and sdrplay I can utilise
Ubbe
Stockholm, Sweden
In old firmware versions a hit where compared to both database, favorite lists as well as all logs of discovery sessions that had been saved. Don't know about the exact state of current firmware versions, as it was broken many years ago, but when the max recording time where met a frequency (with a specific CTCSS/DCS) where automatically avoided to not interfere with the search process as enough information had already been collected.
The HP-1 scanner doesn't have any digital capability and treat any signal as if it where analog. For the 436/536 they first didn't have any DMR capability and discovery mode worked fine and the same as in a HP-1 but when DMR where added then some functions where compromised. Maybe firmware developers where trying to do something to compare digital hits to previous records in conventional discovery mode but instead managed to mess up the firmware code.
/Ubbe
VK3YMML
Melbourne, Victoria
Hi Ubbe
Even though I logged all the frequencies I didnt note down the CTCSS or DCS so all matches are coming back as new, so I gather I have some work cut out. Discovery was listing frequencies as "new" even though they were listed in the frequency database.
What I could do is commandeer my 536PT, run Proscan and have all the Conventional channels scanning and it should record the relevant CTCSS/DCS as each channel is activated.
On further notation in Australia, the Uniden 436PT/536PT comes out of the box with built-in P25 (Phase 1 and Phase 2) capability, but DMR and NXDN are not included natively; instead, they require optional, paid firmware upgrade keys purchased separately.
The Uniden HomePatrol series (such as the HomePatrol-1 and 2 and BCD536HP) is not officially localized or sold for the Australian market. Their preloaded databases and location-based zip-code features are built strictly for the USA and Canada
K2RNI
Kingman, AZ
Hi all.
what's a 436PT? I only ever seen the 436HP and 3600XLT models
