Ok, i need someone to point out the obvious that i am missing...... i have the software loaded and working, but trying to get the USB driver to work isnt going well, i have loaded the zip file, extract all files, that leaves me with two file, a XP and Win7 file, i plug in the scanner and nothing is happening? have tried all sorts of combos, plugging in the scannner doesnt trigger anything to start or run? can i try a different usb cord? any ideas?
so far i love this scanner, bought it at the Martinsville Va nascar race this past weekend and really enjoy the functions..
You need to look for the *.inf file (either XP or Win7) from the zip file.
In Windows Explorer (not Internet Explorer), right click on the *.inf file; one of the options should be "Install", select that. This should install the USB driver. After the install, open the "Device Manager" from the Control Panel. Under "Ports (COM&LPT)", you should then see BC125AT(COM**) listed. If you do, your software should be able to find the scanner via the USB cable. (Note: these instructions apply to Windows7, if your in XP (or Vista), there might be a slight difference, but the basic procedure should be the same).
Hope this works,
Ted
the reason why the scanner does that is because it goes into battery save mode if it scanning and not picking up anything.check the manual.
