BC125AT scanning
dispatcher812
Connecticut
I recieved my new BC125AT a week ago and last night had my first chance at using it in the field. I have quite a few frequencies in this from all 97 Railroad Wide band, Railroad UHF, 50 marine chanels, 5o plus Coast Guard frequencies and some Mil air frequencies.
I noticed that while its scanning it will stop on random frequencies form all the banks I have programmed. I do not hear anything, not even a bit of squelch. It just stops for a second or two and then continues. I only have one chanel set as a priority and that is not one it stops on. Close call is off.
One13Truck
My home 20 eating pizza.
I'm not sure if this will be it but for my 396XT I have it set to a primary scan and it'll pause it's regular scanning to check the priority channels for activity. I think I have mine set at 4 seconds so no matter where it's at in the scanning every 4 seconds there's a 1 or 2 second pause while it checks the priority channels. I haven't seen the 125AT in use yet so I'm just throwing a guess. I'm not sure if they both work the same way with the priorities.
kcoleman
Tallassee, AL
Kevin,
You might check to see what firmware you have. I had some odd behavior with mine while on some trips around town. If I recall correctly, most of that stopped after I did the first upgrade.
Hope that helps.
Firmware Changelog
1.03.01 (September 5, 2012)
Add a function to switch from USA to Canadian band plans on power up:
  • Hold 1 during power up to change to the USA band plan.
  • Hold 2 during power up to change to the Canadian band plan.
Improve on the issue reported at: http://forums.radioreference.com/uniden-scanners/232936-bc125at-post-release-thread-3.html#post1742547
1.02.05 (April 27, 2012)
This update makes the following changes:
  • Update the frequency steps in the VHF band to match the latest FCC Narrowbanding band plan.
  • Change the opening screen to include the current firmware version.
  • Apply a one-time routine to convert the memory image of existing channels to the new format required by the narrowbanding change.
  • Change how Marine channels are displayed during service search.
  • Fixed a bug that could cause scanning/reception to stop with certain combinations of Close Call and other features selected.
Keith,
