BC125AT
Ebarneycastle
Gastonia, NC
I have a BC125AT and I would like to know if I can use the RR database to download directly to this scanner. If so, what program? I have tried Freescan and Proscan and neither are compatible with that scanner.
Nasby
Ohio
It is not possible to do a RR download with that model scanner.
Nasby
Ohio
My bad. Forgot about Butel. I was going on Proscan and Freescan.
Good call.
Scan125
UK
Yes credit where credit is due ARC125 can use direct connection the RR Database.
This is something that Scan125 does not currently do, and is unlikely to do, however the Scan125 and Scan125 Convert can handle any CSV data file that you find on the net or you download from RR.
Many ARC125 users use both ARC125 and Scan125 to cover all their needs.
Bob1955
Ebarneycastle, also purchase a Diamond RH-77CA rubber antenna from Amazon. It is the best all band handheld antenna out there. I had that on my Bearcat BC-125AT before I sold it last year.
Ebarneycastle
Gastonia, NC
Will this also work with a BCD325P2?
