BC245XLT Programming
pa_vmedic
El Paso, Texas
A friend of mine asked me to program this particular scanner for him. So far, I have had no problem programming conventional frequencies, but I have an issue programming trunking IDs. Can anyone help?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Be a bit more specific; what system, and where (city/state)?
The answer will depend on what kind of system you are trying to program; EDACS, Motorola (what kind?)....but in general, you need to first put the scanner into trunk programming mode then select the kind of system you are trying to program. At that point, once you've entered that information, you start entering frequencies. PP40-41 of the owner's manual tells you about this. 73s Mike
Pap
Pittsburgh,Pa.
BC245XLT Programing
Go to the Uniden website. The manual is there in PDF format. Just print out
what you need. it's better then someone trying to explain it
LOL Pap in Pgh.
