Bc246t help!
blacktiger
Hey Guys, I have a BC246T Scanner and i lost all of Fremont & Newark, California (Alameda County).Police & Fire Calls. Did they change their Frequencies or System? If so, how do i re-program my scanner to receive them again? Your help is much appreciated!!
kilowa22
Oregon
They have just rebanded that system.
You will need to apply the Version 2.60 update for the BC-246T radio:
http://info.uniden.com/twiki/bin/view/UnidenMan4/BC246TFirmwareUpdate
using Windows
Then you will need to reprogram the system(s) as Motorola 800 MHz Type II custom and program in the special Band Plan for 800 MHz systems. The ARC-246 Software does support programming rebanded Motorola systems, however the Uniden BC-246T UASD Windows software does NOT support programming Custom systems.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
blacktiger
Bc246t
Guys, thanks so much for the info. I did the firmware update to the latest. Now I will check out your info and see what happens. Again, THANKS!
