Bc278CLT
Tonice
I bid on ebay for a new BC278CLT and won today! now i am not sure if this scanner will allow me to listen to the 900 freq? Can anyone help me with that question? if this model does not, is there any other desktop model that will allow me to listen to 900 frequency?
much thanks,
Tonice :D
nexus
Mississippi
Here is the basic rundown on that model:
100 Channels
12 Band Coverage
5-Banks
S.A.M.E. (specific area message encoding)
Full-Frequency LCD Display
800 MHz
20 Presets
Clock/Alarm Feature
Channel Lockout
Memory Backup
Programmable Scan Delay
Manual Channel Access
Priority Feature
Auto Delay
Weather Scan & Local Weather Alert
One Touch Weather
It will Receive the 800~900 mhz band with cellular portions blocked. However it will not track TRUNKED RADIO. It's a basic no-frills table-top scanner. If who ever you want to listen to isn't using Trunking, then you should be pretty good to go. If they are using trunked radio then you're not going to get much use out of that baby.
Frequency Ranges:
29 - 29.7 MHz (10 Meter Amateur Band)
29.7 -50 MHz (VHF Low Band)
50 - 54 MHz (6 Meter Amateur Band)
108 - 136.9875 MHz (Aircraft Band)
137 - 144 MHz (Military Land Mobile)
144 - 148 MHz (2 Meter Amateur Band)
148 - 174 MHz (VHF High Band)
406 - 420 MHz (Federal Government Land Mobile)
420 - 450 MHz (70 cm Amateur Band)
450 - 470 MHz (UHF Standard Band)
470 - 512 MHz (UHF “T” Band)
806 - 956 MHz (Public Service Except Cellular Band)
Curious, what were your monitoring interests? I mean who did you plan to listen to?
