BC355N Not working
Jv4
I recently purchased a Uniden BC355N to scan local law enforcement agencies and emergency services. I followed the online programming tutorials and the scanner is not putting through any transmissions.
Below are the radio reference channels I am trying to scan (mainly sheriff channels 1 & 2).
Pueblo County, Colorado (CO) Scanner Frequencies and Radio Frequency Reference
Any help would be greatly appreciated.
Thank you,
hiegtx
Mentor
Dallas, TX
Thank you,
Just for clarity, there are some conventional channels listed for Pueblo County & city, but comments on the database page that indicates they are using the Statewide system, DTRS, which, as doc has noted, your scanner cannot receive.
While you could program those conventional channels, they likely are not being used on a regular basis, if at all. They probably kept them, for now, in case the trunked system went down in their area.
Jv4
Thank you both for the fast responses. Are there any devices you could recommend that would work with those channels that don't cost and arm and a leg?
CT
The only thing I can think of is an SDR.
Maybe someone else can make a specific recommendation.
Good luck!
BinaryMode
2600 dialtone blvd
Your scanner isn't capable of receiving Phase II systems and is only capable of Analog.
The Colorado DTRS is NOT phase II. It's phase 1. I know, I live here.
We do have at least one or two other systems that ARE phase II, but the DTRS is not. The scanner is not a digital modulation capable scanner though.
JoeBearcat
Uniden Representative
The 355 will not decode any P25 systems - Phase I, Phase II, or anything else digital.
