And yet the link you provided is not a serial cable (in the common usage), but in fact a null modem cable (that will not work for use on the scanner subjected here). Who is the confused one?ragtime88 said:Sorry but, "modem" cable and "serial" cable are the same thing -- or, *were* the same thing when people used external modems for computer dialup. You'll find that serial cables sometimes carry the old label designation. They're also called RS232c, but I think that's strictly the 25-pin configuration. Most of the pins/wires in a 25-pin unit were never used, so 9-pin emerged. Even in a 9-pin, many are unused (except with synchronous modems). Cheers. --G
Well everything you say here is correct (except for the radio connection bit). A null-modem cable (or crossover cable, or file transfer cable) has the same connection on both ends; hence it can hook to two computers so that they can communicate via the RS232 ports. This was a popular item before every computer came with a LAN port, but really is superfluous in this day and age. A serial cable is just an extension cable, it will have a female end (plugs into the computer) and a male end (plugs into various devices like radios, modems, etc.), all it does is extend the RS232 port from the back of the computer to whatever device you are going to hook it to. I think that you will find when you get your $15 cable, it will have female connections on both ends and then you will be looking for a gender-changer. After you get the gender changer, you will find it will not work because it is a cross-over cable. But at least you will have a file transfer cable, in case you ever come across two computers that you want to transfer data between that have serial ports and no LAN cards.ragtime88 said:Seller calls it a "serial file transfer cable" and actually doesn't use the words modem or null-modem. Yep, there's a difference and you may well be right. I haven't hooked this up yet, but I'm betting $15 that it works. The null-modem cables were bi-directional (you could hook either end to either appliance). In a true modem cable (I think?) one end had to be at the computer and the other end at the modem. I'm betting -- and I apologize for jumping in on this thread ahead of actually testing it -- that the PC to radio connection requires a directionless (null-modem, file transfer, serial) cable. At BestBuy and OfficeMax, their cable charts had these labeled as "modem" cables. My connection will be a PC to BC898T. I'll let you know when I get it hooked up.
Vendor also says, "State-of-the-art wiring design ensures 100% compatibility with all devices" which I don't necessarily believe.![]()
<sigh>CVPI4Ever said:Can someone link me to a cable so I can be done? Y'all got me all mixed up.
Also, can I download the software, burn it to a disk and install it to my laptop?
Sorry for bringing up an old thread but I never got around to this and now I need to. Do the cables have to be a male/male connector?
I found this
Belkin RGb Monitor Replacement Cable DB9M/DB9M 6' Sh at Staples®
